Pro Tools - Presonus FIREPOD - Setting up
I can't get my FIREPOD to work in Pro Tools .
I press and hold "n" on launch, but Pro Tools nags about unsupported buffer size ? Is there a way around this ? Works in REAPER 6 x64 I'm on Windows 11 and with DIGI-002 everything was just fine . - Z - |
Re: Pro Tools - Presonus FIREPOD - Setting up
Things to consider:
1-"unsupported" sample rates often gets mentioned when Windows is using the interface. First thing to try: set Windows Sound Properties to use the on-board sound card as the default playback device(and cross your fingers). 2-what driver are you trying to use with the FIREPOD? I was under the impression that Presonus left that unit unsupported. 3-Since the 002 works fine, why not just use that? If you need more IO, you cannot combine the 2 boxes on any Windows setup(unless you can route the FIREPOD inputs to its ADAT out and feed that to the 002 ADAT in) 4-both these interfaces are old and neither is considered "good" sounding(unless they have Black Lion mods). You may get better advice if you describe exactly what you are trying to do and why
Pro Tools Aggregate set up, digi 003 (rac) + presonus firepod | RickvanDunn | macOS | 1 | 10-27-2011 05:09 PM |
Presonus Firepod with Pro Tools 9 | Prages | Windows | 0 | 05-27-2011 01:09 PM |
presonus firepod | p.richardson3 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 11-12-2010 06:28 PM |
PreSonus FIREPOD and Pro Tools M-Powered | jaredbh | Pro Tools M-Powered (Win) | 0 | 04-19-2007 04:38 PM |
PreSonus FIREpod With Digi002 and pro tools??????? | DrummerGuy09 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-05-2005 08:47 PM |
