NTFS or FAT32
HELLO,
I have digi 001,please help me... should i format with NTFS or FAT32 ? another question: PT LE works with 1024 ddr333, or only 512 ddr333? ROTSH |
Re: NTFS or FAT32
If you run 98/ME -> FAT32, NTFS will not be recognized.
XP supports both formats.
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
Re: NTFS or FAT32
Ditto... I use Fat32 with my external Glyph firewire without problem in WinMe. Should be XP compatible, when I move.
Digi002R PT6.7 SP1 K8Vdx AMD643200 GeilPC32001G HitSATA80GB(sys) 2xSATA160GB GlyphXFW NEC2500DVDRW Sapph9600ProU SonyP234LCD AntecSonata Zalman7000Al |
Re: NTFS or FAT32
If you're using XP and never plan on using 98/Me on that drive, go with NTFS... It's a tad faster, and a lot more reliable.
Re: NTFS or FAT32
Is there any real proof that it's better to run NTFS?
How will PT benefit from doing so? |
Re: NTFS or FAT32
thanks
i use XP home edition. i have 2 * h.d: 1. w.d 7200 ata100-sys. 2. maxtor 7200 ata 133-audio. is it o.k ??? |
Re: NTFS or FAT32
yes. fast enough. I have a Quantum ata66 and can run all the 24 tracks with no problem...
Re: NTFS or FAT32
NTFS tad faster and more realiable? Agree with RunRun, not sure that information is correct. Mac compatibility, however might be an issue? [img]images/icons/confused.gif[/img]
Re: NTFS or FAT32
allen,
please help me with this question. format FAT 32 or NTFS ? THANKS |
Fat32 or NTFS? | sgladm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 08-07-2006 09:54 PM |
NTFS or FAT32??? | silence_of_stone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 03-19-2003 07:03 PM |
FAT32 vs NTFS | vanb777 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 01-20-2003 07:00 PM |
NTFS or FAT32 | darkwar3 | Pro Tools TDM Systems (Win) | 2 | 09-26-2002 12:28 AM |
NTFS or FAT32? | smit1_uk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 25 | 06-21-2002 12:01 AM |
