Old 07-21-2017, 10:36 AM
Anibal Anibal is offline
Default Drives not mounting on restart!?!?
replacing some old audio drives on my Mac Pro... when I start the computer no issues... if I restart the drives don't mount, I have to turn it off turn on again and they mount no problem... can't find an answer anywhere... anybody?
they are WD Black 4TB.
thanks.
PT 2018 HDX 1
Mac Pro Westmere 12 core 3.46 OSX 10.12.5
64 gig ram
Old 07-21-2017, 10:39 AM
john1192 john1192 is offline
Default Re: Drives not mounting on restart!?!?
thanks.
any errors or messages come up ?? a Circles with a Slash through it .. ?? how full are the drives ?? when did this start ?? did you do anything ;ike an OS update ot PT update ??
more info please ..
cheers john
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 07-21-2017, 10:56 AM
more info please ..
cheers john
no, no errors, drives are about half full, no updates on PT or OSX...
PT 2018 HDX 1
64 gig ram
Old 07-21-2017, 12:32 PM
Tweakhead Tweakhead is offline
Well known issue with these drives. Affects PC users too.
https://community.wd.com/t/wd-black-...-reboot/184343
Old 07-21-2017, 04:21 PM
The Weed's Avatar
The Weed The Weed is offline
From PT on XP to PT 12 on W10 and probably 10 WD Caviar Black drives on 3 computers - with and without PT - I've never had that issue happen. Of course, now that I've said that...
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 07-22-2017, 09:14 AM
thank you Tweakhead.... now I know...
PT 2018 HDX 1
64 gig ram
Old 07-22-2017, 09:36 AM
ramonetl ramonetl is offline
I used to use the WD black drives but never recall that issue. I did have a lot of problems with Missing drives that caused me to roll back El Capitan. When I got my new mac pro in January I went straight to a clean install of Sierra and no issues. I have several of the Lacie Porsche drives connected and they are flawless and have up to 8TB if you store a lot of stuff. I would recommend those if you decide to upgrade. Quiet, look really cool and you can stack en 3 high which makes it very space efficient. I have 5 connected...
Old 07-22-2017, 09:52 AM
I have went through 150+ of these drives the last few years. I have had problems with maybe 4-5.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 07-23-2017, 09:47 AM
jeam25's Avatar
jeam25 jeam25 is offline
Hi !
Do you see them on disk utility when they aren't mounted by any chance ?
Also double check your cable conections .
Mac M1 Studio Ultra - Sonoma Beta OS
Avid Carbon Interface
Protools Ultimate
Old 07-23-2017, 11:02 AM
Same issue with 2 WD Black 4TB drives here. Yes, it's s a known issue on both Mac and PC. They only mount after starting the computer not after a re-start.
aonly happens with the 4TB and up afaik.
Frank
minor annoyance with mounting drives Guruman Pro Tools TDM Systems (Mac) 1 05-11-2006 09:29 AM
Mounting removable scsi drives in OSX schiffdigital Storage Subsystems 2 05-24-2003 09:46 PM
Mounting HFS+ Drives on a PC... fifthcircle Pro Tools TDM Systems (Mac) 2 04-25-2003 10:47 AM
turning off unmounted drives and mounting turned on drives marcnyc General Discussion 3 02-14-2003 10:04 AM
Drives Formatted With Atto Not Mounting nrgmusic Pro Tools TDM Systems (Mac) 5 12-23-2000 11:52 PM
