003Rack+ Driver-Less, PT LE 8
I recently obtained PT LE 8 and a 003Rack+, and it appears that there are no drivers for the 003.
I've installed 8.0.5. I only have one hard drive right now, in the process of purchasing another. I am currently using a PCIe Firewire card I purchased. SiSoftware Sandra Computer Model : HP p6650z Workgroup : WORKGROUP Host Name : Woodle User : Chris Processor Model : AMD Athlon(tm) II X4 635 Processor Speed : 2.9GHz Cores per Processor : 4 Unit(s) Threads per Core : 1 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 64kB, Synchronous, Write-Back, 2-way, Exclusive, 64 byte line size L2 On-board Cache : 4x 512kB, ECC, Synchronous, Write-Back, 16-way, Exclusive, 64 byte line size Computer Mainboard : FOXCONN 2AB1 BIOS : AMI 6.04 09/07/2010 Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3.75GB DIMM DDR3 Chipset Model : HP RS780 Host Bridge Alternate Front Side Bus Speed : 2x 2GHz (4GHz) Shared Memory : 256MB Channels : 1 Memory Bus Speed : 2x 100MHz (200MHz) Chipset Model : AMD F10h Athlon 64/Opteron/Sempron HT Hub Front Side Bus Speed : 2x 2GHz (4GHz) Total Memory : 4GB DIMM DDR3 Channels : 2 Memory Bus Speed : 2x 667MHz (1.33GHz) Memory Module(s) Memory Module : Micron 16JTF25664AZ-1G4F1 2GB DIMM DDR3 PC3-10700U DDR3-1334 (10-10-10-27 5-37-11-6) Memory Module : Micron 16JTF25664AZ-1G4F1 2GB DIMM DDR3 PC3-10700U DDR3-1334 (10-10-10-27 5-37-11-6) Video System Video Adapter : ATI Radeon HD 4200 (40 SM4.1 500MHz, 256MB 2x667MHz, Integrated Graphics) Graphics Processor STREAM Processor : ATI Radeon HD 4200 (40SP 2C 500MHz, 256MB 2x667MHz, Integrated Graphics) Storage Devices WDC WD6400AAKS-65Z7B0 (640.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 596GB (C:) (D:) Generic-SD/MMC (USB) : N/A (F:) Generic-Compact Flash (USB) : N/A (G:) Generic-SM/xD-Picture (USB) : N/A (H:) Generic-MS/MS-Pro (USB) : N/A (I:) hp DVD-RAM GH60L (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:) Logical Storage Devices SYSTEM : 100MB (NTFS) OS (C:) : 584GB (NTFS) @ WDC WD6400AAKS-65Z7B0 (640.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) HP_RECOVERY (D:) : 12GB (NTFS) @ WDC WD6400AAKS-65Z7B0 (640.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) Removable Drive (F:) : N/A @ Generic-SD/MMC (USB) Removable Drive (G:) : N/A @ Generic-Compact Flash (USB) Removable Drive (H:) : N/A @ Generic-SM/xD-Picture (USB) Removable Drive (I:) : N/A @ Generic-MS/MS-Pro (USB) Optical Drive (E:) : N/A @ hp DVD-RAM GH60L (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : HP IXP SB600 SMBUS Controller LPC Hub Controller 2 : HP SB700 LPC host controller LPC Legacy Controller 1 : T2 87-21 Audio Device : HP IXP SB600 High Definition Audio Controller Audio Codec : Realtek Semiconductor 888 High Definition Audio Audio Device : ATI (AMD) RS880 Audio Device [Radeon HD 4200] Audio Codec : ATI (AMD) HDMI Audio Disk Controller : HP SB700 SATA Controller [AHCI mode] USB Controller 1 : HP SB700 USB OHCI0 Controller USB Controller 2 : HP SB700 USB OHCI1 Controller USB Controller 3 : HP SB700 USB EHCI Controller USB Controller 4 : HP SB700 USB OHCI0 Controller USB Controller 5 : HP SB700 USB OHCI1 Controller USB Controller 6 : HP SB700 USB EHCI Controller FireWire/1394 Controller 1 : 13330 XIO2213A PCI Express to 1394b OHCI with 3-Port PHY SMBus/i2c Controller 1 : ATI SB600 SMBus SMBus/i2c Controller 2 : ATI AFS SMBus Printers and Faxes Printer : PDF Complete Converter (2400x2400, Colour) Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Peripherals Media Player : () Media Player : () Media Player : () Media Player : () Network Services Network Adapter : Realtek PCIe FE Family Controller (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Home 6.01.7600 Platform Compliance : x64 Windows Experience Index Current System : 4.2 Performance Enhancing Tips Warning 100 : Large memory sizes should be made of Registered/Buffered memory. Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
Re: 003Rack+ Driver-Less, PT LE 8
Also, during the installation process of PT8, am I supposed to be prompted to enter the Registration ID?
Download and install these drivers. Install with 003 turned off then reboot with it turned on; http://avid.custkb.com/avid/app/self...3=1450&Hilite= Also, while connected to internet go to Control Panel>Device manager>double click IEEE1394 bus host controllers>double click first controller>Driver Tab>update driver, Search Automatically>OK. Do same for any other IEEE1394 controllers listed. There are a couple of things that may cause performance issues once you have PT up & running; You only have one HDD when you need to record to a separate drive. So you need a minimum of two. Integrated graphics can cause problems also.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
There is no separate driver installation for PT8, the drivers are automatically installed as part of the PT8 install.
Also, Windows 7 has a nifty little "feature" where it installs its own drivers when it finds new hardware at boot (see my post #15 on this thread for details http://duc.avid.com/showthread.php?p...=1#post1792191). First shut down and disconnect your 003R+ (no hot plugging!) Remove PT8, then search Device Manager for anything related to PT or the 003 and remove it. Install PT8. Shut down, reconnect your 003R+, restart, and you should be good to go...
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
Thanks so much! |
Excellent! Now go make some noise
re: digi 003Rack | 2224 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-01-2012 11:51 PM |
003rack + windows7 64bit = asio driver problems | johnut | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 05-25-2011 06:28 AM |
003rack+win7-64bit PC+digi asio driver = midi input (5pin) problem! | Slaido | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-22-2011 06:32 AM |
7.4.2 and rewire-003rack | iRECORD | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-30-2008 08:24 PM |
003rack and latency | davpond | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-01-2007 07:35 PM |
