  #41
Old 01-09-2025, 11:02 AM
Joe Costa Joe Costa is offline
Default Re: M4 Mac Issues
Originally Posted by thebeatless View Post
Tried the M4 Max again with 2024.10.2. No change!! Got this error after a "bounce and import" about 20 min into testing the system.
I'm still on my older system and was slowly doing installs on my new M4 Pro. Haven't had time to install everything and start using it. I was going to try running in rosetta if i ran into issues. If you run protools on your M4 in rosetta, do these issues still occur?
PT 2024.10.2
MacOs 15.1
Mac Mini M4 Pro
48g unified memory
PT 2024.6
MacOs 13.6.6
Mac Mini 2018-2020 i7
1tb SSD
32g of ram
  #42
Old 01-11-2025, 04:57 AM
thin ice thin ice is offline
There is an iLok update for anyone running into issues.
Mac Mini M4 24GB
OS 15.2
PT 2024.10.1
  #43
Old 01-12-2025, 04:38 AM
XJENSEN XJENSEN is offline
Experiencing bounce issues on M4 and Sequoia 15.2.
Offline bounce works fine, but online bounce seems to complete but at the very end throws an AAE-9171 error.
Logged a case.
  #44
Old 01-15-2025, 05:34 AM
Purplesound Purplesound is offline
Made a case for the duplicating/creating tracks problem (assertion error).
It seems to happen only when opening sessions that were made before 2024.10.1.
  #45
Old 01-15-2025, 09:39 AM
Some new information from Sonnox re M4.
https://support.sonnox.com/support/s...-apple-m4-cpus
PT 2024.10.2
MacOs 15.1
Mac Mini M4 Pro
48g unified memory
PT 2024.6
MacOs 13.6.6
1tb SSD
32g of ram
  #46
Old 01-17-2025, 04:51 PM
fsavell fsavell is offline
Going to start a case, but interested if anyone else has seen the Bounce Mix... menu option getting greyed out on M4?
Once the bug happens, nothing seems to restore the Bounce Mix... option other than a restart or trashing preferences. Trashing prefs seems to give more time before Bounce Mix greys out, whereas quitting only gives one session load/bounce before occurring.
Chalking it up to M4 Macbook Pro issues.
Pro Tools Ultimate 2024.10.1, HDX1 • Mac Studio M2 Ultra - macOS 15.1.1
  #47
Old 01-17-2025, 07:06 PM
thebeatless thebeatless is offline
Yes, this happened to me many times. My extremely expensive m4 Max MacBook is still completely unusable for work. I purchased it as an upgrade for my pro tools system because of the impressive increase in cpu benchmarks, but it is just being used for couch surfing and Zwift until these issues are fixed.
  #48
Old 01-18-2025, 08:46 AM
smurfyou smurfyou is offline
No offense but Avid never said they were compatible. New Macs are pretty much never qualified in advance.
~Will
  #49
Old 01-18-2025, 08:56 AM
Duh, but I needed a new computer after my m1 was damaged. I wasn't going to buy an older model. I started the thread knowing it was too soon to expect an immediate fix. It's just frustrating since things have mostly been fine on the hardware side of things. In recent history, or at least since the introduction of apple silicon, if the OS is supported, the hardware has worked. I know apple is to blame, not Avid.
  #50
Old 01-18-2025, 09:08 AM
Didn't realize you were the OP. Very frustrating. I've been in the same boat.
~Will
New laptop, issues launching protools - now issues with Ilok after re-install tsfisk Licensing & Accounts 6 07-30-2021 06:31 PM
Mbox Gain Issues and Protools Issues (Bounce to Disk and Knob/Pot adjustments) Lucky Bastard Getting Started 6 01-16-2014 04:29 PM
No sound - asio driver issues - NTFS issues mitchelljrickey Windows 0 06-21-2012 06:35 PM
ProTools 9.0.5, iLok issues, Digi 003R+ issues zachbot Pro Tools 9 6 10-12-2011 09:19 PM
Digital Noise Issues - Clock Source Issues? Gorbies 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-07-2010 02:55 PM
