Originally Posted by Ptbright
Thanks Matt. That’s actually way closer than I had imagined.
Do you perhaps have the figures for 96kHz? Also, when you say depending on which Apollo, are you referencing duo vs quad, gen 1 vs 2, desktop vs rack, or other?
Thanks
Generation and output both matter. The X series has higher latency than the older units at 48kHz and below, due to the better DA conversion.
At 96kHz all Apollos are the same, pretty much.
1.1ms RTL at 96kHz on Apollo.
IF AutoTune Hybrid AAX latency is still 76 samples at 96kHz you'd be looking at about the same RTL on Carbon.
