  #31
Old 09-11-2024, 07:58 AM
smurfyou smurfyou is online now
Default Re: "Audio processing deadline was not met"
Originally Posted by Arno Peeters View Post
Exactly my experience. Had Avid also look into it and they finally advised me to make a new user to see if it still occurs there. I had to explain that amidst all the work I do, I don't have time to literally make all settings again (shortcuts, presets and the like).
Yes I've had to tell them that as well. I like to do everything I can to investigate and report bugs properly but they're not paying me and my clients are.
Meanwhile I'm still getting the error. I think only with DearVR Monitor. I didn't want to call it out but they haven't been able to reproduce or find a solution. An earlier version of the plugin did not cause it.
~Will
  #32
Old 09-11-2024, 08:16 AM
Arno Peeters's Avatar
Arno Peeters Arno Peeters is offline
I use DearVR in almost all my sessions, but not Monitor.
Arno Peeters
Tape TV Productions
  #33
Old 09-21-2024, 05:14 PM
Songster Songster is offline
Originally Posted by marianna View Post
Same exact error message as Arno is getting?
Marianna
Hi Marianna ... this is Nick Allegro
I started having this same issue recently with all of my sessions and with different plugins. The sessions are not large sessions. There is maybe 1 or 2 midi instruments, and on some sessions, there are none, or they have been bounced to audio tracks and made inactive. This is getting very frustrating especially since I'm Mentoring people and this is happening regularly.
I'm still using the same PC I've been using, and haven't changed anything except updates. This just came out of the blue and is really affecting my workflow.
I've been using Studio One more and more because of this error. Most of my sessions and mentor calls I use Pro Tools, so this is now costing me money.
I really don't have the time for the multiple troubleshooting steps especially when the same plugins have been working without a problem and still work on Studio One with no errors.
Any help would be appreciated ... funny, how this always seems to happen right around the time I'm supposed to renew my program? ..
Thanks in advance ... you have been a great advocate for the consumer.
  #34
Old 09-23-2024, 02:18 PM
marianna's Avatar
marianna marianna is offline
Nick
Let me get a case going and see what can be done here... cn you provide a few plug-in examples ( names please ) so I can investigate the?
Marianna
Marianna Montague
Sr. Dir. CX and Community | Customer Advocate
[email protected]
cell +1 (813) 493-6800
AOL IM avidmarianna
Twitter Avidmarianna
We're Avid. Learn more at www.avid.com
  #35
Old 09-26-2024, 11:29 AM
postprosound postprosound is offline
Having major issues here as well. For me it always seems to be any izotope plugin. What's funny is that there will be no audio in that area of the track, or even on the track. the plug in is in bypass. some times it will give me the error, other times not.
I simply see no cpu spikes. in fact, the cpu never goes about 10%
I have updated all isotope plugs, deleted prefs, changed drives, upped the buffer size, literally everything. Am I missing something?
We, in post sound, are illusionists, not magicians.
  #36
Old 10-10-2024, 10:20 AM
foret_sombre foret_sombre is offline
Exact same problem here with Fabfilter plugins (Q3, C2, MB, all up to date) but only when importing the tracks from a pre-existing session that has the problem initially (despite cmd+alt+/ to remove all old automations).
Recreating the track from scratch and moving clips and automation from the "corrupted" track can help a bit but not always.
There is no way to trigger the problem intentionally, it can happen dozen of times in an hour, only three times in a day or never at all. With other sessions on the same machine (which have the relatively same layout of inserts, same amount of tracks or more) I never had the problem.
Mac Studio M2 Ultra, Ventura 13.6.9, Pro Tools 2024.6 (it happened before with Pro Tools 2023.9 to 2024.3, Monterey 12.x and a M1 Ultra)
  #37
Old 10-10-2024, 08:49 PM
Interesting I'm on a very similar system but have never seen it with Fabfilter plugins.
~Will
  #38
Old 12-07-2024, 07:55 PM
Nick
Marianna
Marianna,
This was happening with different plugins but for sure SoundID from Sonarworks, and Verbsuite from Slate Digital.
Thanks for your help
  #39
Old 12-08-2024, 07:33 AM
K Roche's Avatar
K Roche K Roche is online now
Nick
Marianna
For me the only time it happens (and happens often) is when I have Nugen Master Check on the Master Fader
And this is on sessions with say 4 to 8 audio tracks and maybe 2- 4 VI instrument tracks and a couple Aux tracks
I thought I would try putting it on my main Mix bus instead and see if that makes any difference. (don't know why it would but thought I would experiment anyway)
I'll report back
System :
Studio - Avid Carbon interface , PT Ultimate 2024.10.2 Mid 2020 (intel) iMac 27" OS Sequoia 15.2
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.10 --Sequoia 15.1
Enjoy the Journey
.... Kev...
  #40
Old 12-09-2024, 08:18 AM
marianna's Avatar
Marianna,
Hi there... Songster
I know you haven't been in the studio lately but when you can - would you try this please? I reopened the case and will take it over so Manuel doesn't close it again. :)
" Can you test a new blank session with just the "Sound ID" plug-in inserted?
If the issue is reproduced, can you send the latest Pro Tools log?
Here's how:
https://avid.secure.force.com/pkb/articles/en_US/troubleshooting/Exporting-Log-files-from-a-Pro-Tools-System"
Anyone else having the issue please do the same and if you have a case send it thru there and if not DM me.
Marianna
Marianna Montague
[email protected]
AOL IM avidmarianna
"Audio Engine Play Startup Deadline Was Missed"... Johnjohnjohn Pro Tools M-Powered (Win) 2 07-07-2009 01:05 PM
"audio engine plays starup deadline was missed" message in pt 8 nachonieto 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 05-31-2009 03:34 AM
Digi: update on "missed audio engine deadline"? H-man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-29-2009 12:20 PM
Digi: update on "missed audio engine startup deadline" H-man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-05-2009 12:54 PM
"Audio engine play start deadline was missed." Huh? mixboy bob Pro Tools TDM Systems (Mac) 1 01-09-2009 12:56 PM
