Old 02-13-2006, 08:11 PM
Erik Sojdelius Erik Sojdelius is offline
Default PT7 Registering Error
Good Evening!
I have installed PT7 but when I try to register I get this error message:
"Error Occurred While Processing Request
Parameter 2 of function Left which is now 0 must be a positive integer
Please try the following:
Enable Robust Exception Information to provide greater detail about the source of errors. In the Administrator, click Debugging & Logging > Debugging Settings, and select the Robust Exception Information option.
Check the ColdFusion documentation to verify that you are using the correct syntax.
Search the Knowledge Base to find a solution to your problem.
Browser Mozilla/5.0 (Macintosh; U; PPC Mac OS X; sv-se) AppleWebKit/417.9 (KHTML, like Gecko) Safari/417.8
Remote Address 83.227.205.80
Referrer http://www.digidesign.com/support/reg/reg_1.cfm
Date/Time 11-Feb-06 03:29 PM"
I must say that I do not understand much of this, suggestions anyone?
Thanks In Advance,
Erik Sojdelius
Old 02-13-2006, 08:20 PM
Avid's Avatar
Avid Avid is offline
Administrator
Default Re: PT7 Registering Error
Hi Erik,
That's a database error, not sure what caused it. Nothing you can do on your end to solve the problem.
Just send your registration details, the same as requested on the registration page, to Digidesign Customer Service Administration:
[email protected]
They'll register you manually.
Administrator
minister's Avatar
minister minister is offline
me too! i had the exact same problem.
the registration is confusing.
i am still wating to hear back from DIGI csadmin
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Continuing "error" message when registering MBox(3) basslines 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-21-2010 09:39 PM
Registering PT8? Gothboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-08-2009 02:33 PM
registering 7.3 bee.r 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 09-19-2008 12:56 PM
Why don't my mics zero out? It's always registering at 50% blkdog7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 04-26-2007 07:32 AM
XP registering matocaster1202 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-22-2002 11:11 PM
