Re: Does Quick keys work on a 001
Rail Jon Rogut
.. your misguided. WHy would you ever make a Quickey a "letter"? THe point being , you simply make the shotcut an "f key" or a modifier action. ( two keys) ITs not a hassle at all. Anyone who buys quickeyes has the same response.. " why isnt this part of the Mac system. Trust me folks, Quickeyes makes LE 300% better. I work on a TDM and a LE system equally as often. I have very few advantages on my TDM system over the LE. I basiclly run both as is they are the LE system, this way I dont ever run into issues. THe few TDM advantages are things like being able to move regions up and down tracks, and other stuff like that. THe limitations are certainly a drag in LE, but you get over it pretty quick. QUICKEYES RULES!!! I have though about setting up a trading post for quickeyes made for LE. THe only issue is that some of the directions that Quickeyes uses are machine specific ( for example, they may look for specific drive names and specific folder names) However, I have made a QUICKEYS travel cd, that I take on the road with me. THis way when I go to a studio with a Pro Tools rig, i can customize in a flash. THe first 20 minutes of eery session I work on is setting up my mouse and its special button assignemts, then I install quickeyes and make sure all my strokes are in order. I realize it a super geek move. But It only takes about 5 minutes of editng before I hear " Wow.. You are so ***** fast on that thing!" |
And by the way...
I dont leave Quickeyes installed on the studios mac. I have absolutely no qualms with bringing software I bought to a Mac that I am working on. Ill go to the supreme court on this one! |
Chompers
I'm hardly misguided.. if you read the original question - he want the same keystrokes in LE that he has on the TDM version when in command mode -- which use single keystrokes. Rail
I installed QK and started to assign the keys. Most worked great. I tried to make them as close to the TDM short cuts as possible, only I add the shift key to everything so that I can still type.
I also assigned a quick key to open a audiosuite Plug and that also worked like a charm. At the end of the day, I think it helps out a lot. 2 thumbs up |
Sorry Rail Jon Tugnut..
I didnt think the poster was needing the exact same keystrokes. I see your point. Still Quickeyes is worth the time and money. |
Pressed some keys now shortcut keys wont work (T,R to zoom etc) | Falcon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 06-11-2016 10:49 AM |
Quick Keys!! ? ? | Javier Santiago | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-04-2007 11:02 PM |
Quick-keys..& X-keys | Ru_C | Pro Tools TDM Systems (Mac) | 10 | 10-24-2006 11:13 AM |
quick keys | RBaker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 07-11-2006 09:42 PM |
function keys don't work as quick keys | miked45 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-21-2003 10:32 AM |
