Old 05-22-2012, 01:25 PM
jimst57 jimst57 is offline
Default 10.2 Window Configuration Problem?
10.2 is running great now on my Windows 7 machine. No more freezing.
But I'm having a window sizing problem since installing 10.2. It may be a setting that I'm missing so I thought I'd ask.
I have 2 displays set up as extended. I keep my mix on the right screen and my edit window on the left. Since installing 10.2, everytime I open Pro Tools I have to click on the Windows Maximize button (upper right corner of the Pro Tools window) to make it fit over to the extended screen. Then I have to resize the mixer window to fit.
I remember before 10.2 however I saved and closed the session was how it reopened.
Is this a setting I might have screwed up in the install of 10.2?
Thanks.
Old 05-22-2012, 01:51 PM
notedmusic notedmusic is offline
Default Re: 10.2 Window Configuration Problem?
I have a similar setup. What I do is just de-maximize it and stretch it out manually over both screens and it remembers that. I'm not even sure how to set it up for dual monitors, but i'm sure there is a setting somewhere... If you uninstalled your setup correctly, everything should be set to default again, so you will have to change the setting.
Best,
notedmusic
Composer/Sound Designer
Pro Tools 11 HD, 64Gb ram, 12tb SSD, 1909
HD Omni/Thunderbolt Native
A bucketload of libraries
www.Reverbnation.com/jedediahjenk
www.soundcloud.com/jedediahjenk
notedmusic.wix.com/jedediahjenk
Old 05-22-2012, 01:59 PM
Brandonx1 Brandonx1 is offline
You can just set the screens how you want them, then close PT with the X box in the upper right hand corner. Then PT will remember your window settings.
Old 05-22-2012, 03:15 PM
I'll give that a try later tonight.
Old 05-22-2012, 03:22 PM
Getting the screens how you want them then hitting and closing out w alt+F4 used to be the resolve for it to remember the size settings
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 05-22-2012, 03:28 PM
TOM@METRO's Avatar
Yup. Or one step better; go get Bob Nagy's "Skootch" utlity.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 05-22-2012, 04:00 PM
Emcha_audio's Avatar
Is it working for pt 10?
Manny.
Wave-T.com
Old 05-22-2012, 04:39 PM
TOM@METRO's Avatar
Skootch works very well with PT10.xx.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
Old 05-22-2012, 05:01 PM
Shan's Avatar
Shan Shan is offline
Yep. I was on the phone with Dr. Robert last night to make sure all is well with Skootch and 10.2. I had an older version so make sure you have the latest.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 05-22-2012, 06:41 PM
justus1900 justus1900 is offline
I have the same problem just updated to Pro Tools 10.2.0 and I have 2 Dell 22inch Monitors and now the Mix Window will not spread across both screens? I can have the Mix on one side and the edit on the other side but I cannot spead the Mix across both Monitors and see the whole Mix?
Producer/Engineer/Musician
RIAA Platinum Sales Award: Lisa Stansfield "Affection"
Main:
Model: Dell 5750 Precision Workstation
OS: Windows 11 Pro 64bit
CPU:*Intel Core Processor i7-10750H (6 Core, 12MB Cache, 2.60 GHz to 5.00 GHz,
Memory:64GB, 2X32GB,DDR4 2933Mhz Non-ECC
OS M.2 512GB PCIe NVMe, Record Intel 1TB SSD, 2T SSD, 1TB SSD
Focusrite Scarlett 18i20 3rd Gen
AVID Pro Tools 2023.12
JBL LSR4328P 8"
JBL LSR310S 10 inch Powered Studio Subwoofer*
Yamaha HS50M Studio Monitors
Alesis Elevate 3 Studio Monitors
M-Audio Axiom 61 Midi Controller
Window Configuration Bug - Track/Groups window keeps reappearing! cantgetnosleep 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-25-2010 11:34 AM
window configuration problem in 8 x9blade 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 02-02-2009 05:48 PM
window configuration short cut sbag 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 01-29-2009 11:20 AM
Window Configuration tsr2 Pro Tools TDM Systems (Mac) 2 09-22-2008 03:47 AM
Window Configuration Bug tj_davies Pro Tools TDM Systems (Mac) 3 11-01-2007 01:32 AM
