Could someone explain “Tick and sample base”
1) Could someone explain “Tick and sample base” selection to me in detail please. I thought I knew the difference between the two however I discovered that there is a new menu in PTS 7.3 where by, by default the Tick base option is selected, as one opens up new track(s) it default all tracks to tick base. This should not be different from PTS 7.1 to the new PTS 7.3 I thought. I discovered my timing problems are directly related to the default which selects tick and base tracks. My issues are if I record in a new or old session (Old meaning session from PTS 7.1) the first track(s) most of the time are in time with the click, track added in real time would record in time correctly however playing back the track(s) would be played out of time. I didn’t have this issue with PTS 7.1 this is why I did not think my problem with the timing would be related to tick base option, or even think this to be the cause.
2) I have discovered that my Digi002 have a limitation with the Adat a maximum sample rate of only up to 48khz. I was very disappointed with this limitation. I am using the Focusrite Octopre Pre-Amp for additional 8 XLR’s with phantom. |
Re: Could someone explain “Tick and sample base”
With respect, Sample/Tick-Base Timing is covered in the Reference Guide.
filosofem
Aaron Mulqueen - 001 HD Native |
happy tooling,
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
The only way higher sample rates can be carried over lightpipe is by a duplexing technology called S/MUX, in which each channel of the lightpipe is paired with another to produce 96kHz (2 x 48 = 96). Since this technology uses two channels of the lightpipe for one full channel of audio, it reduces the track capacity of the format from 8 to 4. There is no Digidesign LE hardware that is capable of S/MUX. There are some M-audio units that are compatible with Pro Tools MPowered that are.
I had a looked at the manual again and I said please explain tick and sample base in detail. The manual do not cover in detail!!!!
I copied this here from the Reference Manual hoping to get your feedback on exactly what it is that you are having a hard time understanding. Hopefully you can point that out to us. I think it is a pretty straight-forward and detailed explanation of the differences, but maybe you have a different problem that I'm just not perceiving.
Shawn, that was exactly what I wanted to know, what specifically did he/her want to know. Personally, the definition given by the Reference Guide is comprehensive and straight forward.
filosofem
Well I had to go this long route to make my point with the timing issue that does not work as it should. Other wise I would have had all sorts of funny quotes from people here as to for example it is pilot error ECT….. I think we all could do without the smart ass remarks and let’s assist one another. Now the manual in this regard in PTS 7.3 has not change as you so quoted and explained here “tick base is related to midi and sample base are related to audio. The one thing both has on common is taken from your quote is “it will not move out of time just and only tempo change “ONLY”.
from that location if the tempo changes” (audio) “it will not move from that location if the tempo changes (midi). Do you see my point? By default tick base now in PTS 7.3 is ticked in preference menu under edit, however not just the audio but midi too is effect in regards which is playing out of time in PTS 7.3. Because there is people (one then) that shoot his mouth off before he has the facts. |
If you take this as being a smart ass remark ...so be it! Bye! filosofem
What would the purpose be of using tick based timing on an audio track? Maybe if it was a click track, or a track with a ton of regions that needed to follow the bars and beats, but you should be using tick based for midi and instrument tracks, and sample based for audio tracks, at least In My Opinion. You should be prompted when you create new tracks what you want them to be, Tick or Sample, or you can do it on the strip itself. Are you using a template to open sessions, one that maybe you made by making all the tracks tick based? Are you changing your tempo ever? I ask because I am about to go to 7.3, and am curious about this "bug", but in all honesty, if SPK says its good, it probably is perfect, or near perfect.
It's time to go to 7.3
Sign up for all things....AWESOME! Kris May the music move you |
changing from sample to tick | simplemix | Pro Tools TDM Systems (Mac) | 2 | 08-17-2007 06:12 PM |
“Tick and sample base” in PTS 7.3 | andre67 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-11-2007 12:03 AM |
sample or tick based? | halfguard | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 12-28-2005 03:40 PM |
Tick base & Time base for MIDI track?? | Rodamyot | Post - Surround - Video | 1 | 04-25-2005 04:57 AM |
digi 002 rack - tick, tick, tick, tick, tick | osset | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-20-2003 04:20 PM |
