  #31
Old 09-27-2011, 11:18 AM
the19thbear the19thbear is offline
Default Re: Crackling when moving windows??
done!
thanks alot:)
  #32
Old 09-30-2011, 10:45 PM
OK.
so i it turns out that i only get really bad performance whenever i have ANY rtas wrapped plugin. (tried from different manufacturers - its ALL wrapped plugins)
- i filled all my insert slots (a-g or whatever is the max) with dverbs and the computer could handle it without a single hiccups (was almost dying though, but its ok) - the cpu meter showed 85% and i could move stuff around fine with no problems.
ANd i found the "minimize io latency" checkbox you were talking about - i just had to press "ignore CPU errors" (or whatever its called) - i cant really compare if it helps or not, since PT stops playing any sound as soon as i do that. THe meters dance around and i am playing back stuff, but there is no audio.
So... what are my options?? i really want to use other plugins than the stock ones!
just tested again - if i have the minimize in/out latncy checked, the computer performs really bad, stock plugins or not, but unchecked, the computer (with stock plugins) performs great!
and by bad i mean: unable to playback 24 mono tracks, with 2 inserts each (takes up roughly 32% of the cpu, but teh cpu meter dancing so much up and down that its hard to tell.. and it goes completely in the red if i scroll up/down or adjust an eq. I have left 2 cores for the OS, and it seems that if i go down to 4 cores only, the performance gets a little better, but still WAY unacceptable.
this is on an I7 2600 3,4 ghz, with no IRQ conflicts, no overclocking, fresh install of win7 and pro tools.
  #33
Old 10-01-2011, 09:11 PM
Hmm.[bleep]
I reinstalled pt - this time 9.02 and checked the "minimize i/o latency" and it help alot! My system is usable now!!
I still get some light crackles when i move Windows around/change eq points etc but not nearly as often as before.[bleep]
Wuhuuu!! Still not perfect, but alot better!
  #34
Old 10-07-2011, 07:17 AM
Default
But if i go anywhere near 30-50% cpu usage the system is unusable....
Seems that any rtas Will mess everything up..
  #35
Old 12-20-2011, 07:42 AM
Solved by Using Pro tools 10..
Problems with crackling / static when recording (Windows 7) Mbox2 zorkiii Windows 24 11-08-2015 08:44 PM
moving to windows vonNoblemachine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 05-01-2008 11:02 AM
Moving to windows McGas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-19-2008 03:25 PM
Mbox and windows xp crackling sound Jakob Frandsen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-09-2004 05:05 AM
Moving from Windows 98 to XP brianpatrick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-03-2003 01:41 AM
