Think of Loopback as virtual cabling. For example, I can use a Pre-Fader Send to route audio from Pro Tools to, say, Hardware Output 6 on my interface. I then Loop that signal back to Hardware Input 6 on my interface and in Control Panel>Sound>Recording Tab set Hardware Input 6 as the default.
I have an RME UFX and TotalMix, RME's software mixer, has a Loopback button on every Output. Clicking it Loops the signal back to the corresponding Input. Doesn't matter if there is a real connection on that Input - as long as it isn't being used at that time. I think that Focusrite only has Loopback on one pair, so you're going to be limited, but worth a try.
Take your projects to the next level with a non-union national read at reasonable rates Demos: brucehayward dot com Source-Connect: brucehayward |
![]() Quote:
But if your Focusrite uses Focusrite Control, the one you should start with is the Scarlett 18i8 video. Just go to the Loopback chapter if you are not interested in the rest. Focusrite Scarlett 18i8 Gen3 - EVERYTHING YOU WANT TO KNOW https://youtu.be/tT5wLm5-TMk All interfaces that have loopback will be setup in a similar way within OBS, at least on Windows. For Mac you will still need Blackhole, Soundflower, Loopback (the app), or the new GroundControl Room or GroundControl Caster from Ginger audio, iShowU, or some other app that can capture sound on Mac. Some other interfaces I have reviewed with Loopback are the Evo 4, Evo 8, Audient iD14, and Presonus 1824c. Again, just go to the Loopback chapter, most of these videos are loooong and cover everything in one video. Audient iD14 MKII Audio Interface - EVERYTHING YOU WANT TO KNOW https://youtu.be/fo_VNNhWvTo EVO 4 LOOPBACK - DAW AUDIO INTO OBS or STREAMLABS (Screen capture & Stream) https://youtu.be/nhq0tXpMaJA addendum to previous video NEW - EVO ON-SCREEN CONTROL APP for the Audient EVO 4 https://youtu.be/vMavp4MVVBY EVO 8 LOOPBACK - Stream/Record Your DAW https://youtu.be/PBFwOqb6Bew PreSonus Universal Control Loopback - Record DAW ASIO Audio into OBS/Streamlabs https://youtu.be/B0wLEzyJf-U From my experience, Focusrite and Audient make the most stable Loopback drivers. Although, I have not used an RME interface which are also supposed to have great drivers.
Brian Windows 11 Pro | macOS 12 Pro Tools 2021 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Thnx!
Desktop: PT 2020.5 / Win11 / Intel 11th Gen i9 5.1GHz / 64Gb DDR4-3600 / Gigabyte Z590 Vision D / Focusrite LS56 Laptop: PT 2020.5 / Win10 / older HP ProBook with i7 quad / U-PHORIA UMC1820 Legacy (works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI001 Click for audio/video demo |
RME has some of if not the best drivers in the industry and support their products long after they are legacy. The drivers are also multi-client. As to Loopback, it's simply a click on a button in RME's TotalMix to initiate Loopback on Hardware Outputs back to the corresponding Hardware Inputs.
You can share your Pro Tools audio into Zoom using Source-Nexus!
Simply put the Source-Nexus plugin on an aux track or your master fader, then set the Zoom mic to your Source-Nexus send audio device ("Source-Nexus A" by default) and you're sending a live, low latency feed directly from Pro Tools into Zoom. Works with virtually any other application, and multiple applications simultaneously as well. Check out our latest Pro Tools and Zoom Source-Nexus tutorial on YouTube. The video shows the set up on Mac but it is largely the same on Windows. Source-Bites: Pro Tools and Zoom made easy with Source-Nexus
Source Elements LLC · Be apart, create together. support@source-elements.com · www.source-elements.com Source Elements Academy - Check our educational hub for remote collaboration professionals |
Using Zoom meeting and screen sharing PT audio | jpriggy | Pro Tools 2018 | 32 | 10-12-2021 10:22 PM |
Pro Tools Audio over Zoom | seanmccoy | Windows | 6 | 05-28-2020 07:18 PM |
Zoom H4 as USB Audio I/O Interface for Pro Tools? | dogsbody | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-21-2009 10:42 PM |
Sharing an external drive between mac and windows | danisrael | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-17-2006 09:53 AM |
Sharing HDD with Windows & Mac | Ndless Nite | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-26-2006 07:53 PM |
