Can\'t hear Audio from other Apps.
I have Mac G4 with 10.2.8 and PT 6.1 with 24D card and 2 farms. I have the Digi core audio card installed. Setup is showing the 888 interface that I have and all the usual apps have been added, i.e., Quicktime, Toast, I-tunes, etc. ProTools is not running but I still have no audio for any of these apps through the PT hardware.
Our other suite has the same computer and software versions but with Mix core and one mix farm and 888-24 and they can't get any apps to sound throught the hardware either. Is that just not possible anymore? I guess I can run a wire from the Mac headset jack all the way to my board in the control room but that's a 50 foot run of unbalanced audio and I'm sure it won't be pretty. Any help here? Thanks, Steve |
Re: Can\'t hear Audio from other Apps.
Steve,
The digicore driver was quirky for me too before OS 10.3 and PT 6.4. I'm on a G5 with HD, so can't help really with the Mix setup, but now with 10.3.7 and 6.7 the core driver works pretty well. The only thing I've noticed is that if you quit a PT session at a high sample rate and then start another app at a lower rate the driver won't always work the first time it cycles. Shutting down the app and restarting it to reload the digi driver has always worked though. With the earlier setup, in order to get audio with other apps it was sometimes tricky. PT has to be COMPLETELY shut down before the other app starts. I got in the habit of giving it about 30 sec's after the taskbar indicator faded just to be sure. You might try to reboot and then attempt to play audio with another app without opening PT first. btw- I'm in OKC too, and would be glad to help anyway I can. Good Luck, Aubrey
PT 7.4cs2 | OS 10.4.9 | Dual 2.0 G5 7g Ram | HD3 Accel | 4 FW800 Drives |
Audio stutter with other audio apps beside Protools | gmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-17-2008 06:38 AM |
No audio from Apple Apps. Core Audio problem? | Armando | Pro Tools TDM Systems (Mac) | 10 | 10-23-2006 06:03 AM |
PT7 and other audio apps | brucecoughlin | Pro Tools TDM Systems (Mac) | 1 | 12-09-2005 12:25 PM |
RE:Other Audio Apps | BashinBri | Pro Tools TDM Systems (Win) | 2 | 08-13-2001 06:11 AM |
Non-audio Apps | NoviceDollars | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-04-2001 05:05 PM |
