3 blink delay before record starts...SOLVED!
Somehow, in trying to get the shortcut of "period 2, period" (supposed to choose a memory location but didn't work) I created a situation where PT pauses for 3 blinks of the 'record' light before recording actually starts! I hit F-12 as usual, and now all of a sudden, there is this delay.
Does anybody know how to stop this from happening? I can't make it quit and want to go back to near-instantaneous recording. ARRRRGH. (No this is not pre-roll [img]images/icons/wink.gif[/img] ) |
Re: 3 blink delay before record starts...SOLVED!
Check to see if you have not accidentally enabled the midi "2 bar" count off (not preroll). Look at the transport (fully expanded) second button in from the right.
dk
http://homepage.mac.com/dkrausz |
When I opened the transport all the way the 2 Bars was lit- I bet you've got it... yep.
Thanks dk, you are a wiz! That was drivin' me nuts. |
Stone, you probably already know this, but if you arm the transport record button and then alt + click the transport play button, the transport play button will start to blink when ready and then when you push play PT starts to record right away. I use this mode instead of limiting my record time to get around the wait-to-record lag time of my audio drive.
Cheers,
Press Arm Record then Play and have to wait 3 miniutes before record/playback starts | The Muphin Man | Pro Tools SE and Essential (Win) | 8 | 09-10-2010 07:03 PM |
10 second delay before playback actually starts | Dan Russell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-18-2006 04:15 PM |
Delay before record starts | mampam | Pro Tools TDM Systems (Mac) | 9 | 02-10-2006 02:42 PM |
I PRESS RECORD.. LONG DELAY BEFORE IT STARTS REC!! | sdre9090 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-16-2005 07:13 AM |
looooonnnng delay before record starts | John H | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 07-16-2002 06:55 AM |
