Delay before record starts
Since updating to 10.4.2 and PT 6.9.3r2 I have a one second delay before the playhead moves and recording begins. If I dis-arm from record there is no start delay. My MIDI count off is turned off. Any ideas.
Re: Delay before record starts
Go to the operations tab of your preferences and check to see that you have the 'open ended record allocation' set to a reasonable time limit rather than 'use all available space'.
60 minutes......I have tried as short as 3minutes. I can boot off my other Panther drive and all is well using the same audio drives.
60 minutes......I have tried as short as 3minutes. I can boot off my Panther drive and all is well using the same audio drives.
Reformat your audio drive as HFS+ with Journalling enabled.
Rail
I did that two days before the upgrade.
From the Disk Utility Info Page: Disk Identifier : disk4s3 Mount Point : /Volumes/Studio A RAID File System : Mac OS Extended (Journaled) Connection Bus : Fibre Channel Interface Partition Type : Apple_HFS Device Tree : pci2/IntraServer,fc@4,1/disk@1:3 Writable : Yes Universal Unique Identifier : BFDE86DE-433B-32ED-83DA-AC2370D5A2D9 Capacity : 345.1 GB (370,549,948,416 Bytes) Free Space : 268.7 GB (288,498,978,816 Bytes) Used : 76.4 GB (82,050,969,600 Bytes) Number of Files : 42,214 Number of Folders : 1,791 Owners Enabled : No Can Turn Owners Off : Yes Can Be Formatted : Yes Bootable : Yes Supports Journaling : Yes Journaled : Yes S.M.A.R.T. Status : Not Supported Disk Number : 4 Partition Number : 3 |
What's your DAE Buffer set to (the defualt 2) ?
This drive is hooked up to a SAN ? Rail
DAE buffer is 2 (Default) and yes it is hooked up to an Apple X-serve with Fibre Share X as the software. This has worked perfectly for two rooms for two years. And it is working perfectly on our identical system. That's why I keep thinking it is some preference I am missing
I would check your SAN settings.
There are only 3 things in Pro Tools which can cause slow start time: 1) DAE Buffer size. 2) Open Ended Record Allocation 3) Count-off If you trash your prefs and reset these to 2, 10 minutes and Off respectively.. and you still have a slow start time -- look elsewhere. Rail
Press Arm Record then Play and have to wait 3 miniutes before record/playback starts | The Muphin Man | Pro Tools SE and Essential (Win) | 8 | 09-10-2010 07:03 PM |
Delay until recording starts... | T. C. Gass | Pro Tools M-Powered (Mac) | 2 | 01-10-2006 07:27 AM |
I PRESS RECORD.. LONG DELAY BEFORE IT STARTS REC!! | sdre9090 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-16-2005 07:13 AM |
looooonnnng delay before record starts | John H | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 07-16-2002 06:55 AM |
3 blink delay before record starts...SOLVED! | Stone Knife | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-29-2002 05:24 PM |
