Problems with phantom power
when I try to arm a track with phantom power on i get an error message saying about disabling ac-3 mode. i did a search and found to go into the mac system prefs. and disable it. well i went there and its already disabled. pro rools boots up fine and everything seems to be normal its juat there's a problem when i try to arm a track when I need phantom power.
iMac 20" 2.4Ghz Intel Core 2 Duo, 4GB 667 Mhz DDR2 SDRAM, Guitar Rig Session I/O, M-Audio Axiom25, Pro Tools 10.1.3, Mackie Mr8mkII Monitors |
Re: Problems with phantom power
anyone???...
I've gotta say that phantom power should have no effect on the software. That is all happening out in the analog world before any a/d conversion. What makes you say that phantom power is causing the problem?
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
because everything else works fine except when i need to arm a track that i need phantom power on? i can use dynamic mics and whatever else. just when you hit the arm button on a track with phantom power engaged the error comes up, and ive checked the error about disabling ac-3 in the system prefs. on the mac and it is, and i still get the ptoblem.
Mbox Factory 2 Box - Phantom Power Problems | Mista808 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-11-2010 06:10 PM |
Problems with Mics and Phantom Power | abrax | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-07-2005 11:58 PM |
PHANTOM POWER PROBLEMS | GRIP22 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-12-2001 09:29 AM |
PHANTOM POWER PROBLEMS | GRIP22 | General Discussion | 3 | 05-12-2001 08:52 AM |
phantom power problems | plooked | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-23-2001 11:20 PM |
