Old 06-23-2015, 12:54 AM
mr.armadillo mr.armadillo is offline
Default Copy Plug-In Parameters not working?
cmd-shift c / cmd-shift v to copy & paste plug-in parameters
stopped working for me in PT11. Used to work in 10. Anyone else seeing this?
Old 06-23-2015, 01:22 AM
Farhoof's Avatar
Farhoof Farhoof is offline
Default Re: Copy Plug-In Parameters not working?
Nope working as intended. Be sure to have your plugin window focused (little red square upper right corner).
Old 06-23-2015, 06:01 AM
Weird. Yeah, it's focused.
Old 06-23-2015, 02:01 PM
Postman Postman is offline
Works here on 11 and 12.
Having both AudioSuite and realtime plugin windows open at the same time can cause this. The problem is that the red focus button can be lit in both at the same time and PT may copy from the wrong one. I click off the focus button on all AudioSuite windows that I leave open. When I actually need to copy from AS type to realtime (or vice versa), I use the menu on the plugin windows.
Old 06-23-2015, 02:07 PM
I do have one metering plug-in open (red button deactivated) and the movie window on the same screen. Might be the problem.
HTML code is On
Copy/pasting plugin parameters LightUnderTheDoor Tips & Tricks 5 01-04-2015 10:08 AM
Help: copy/paste plugin parameters (ex: 2.0 to 5.1)? Floydio Tips & Tricks 2 05-26-2010 02:04 PM
"write to all enabled parameters" shortcut not working Eric L Pro Tools TDM Systems (Win) 3 05-05-2007 07:49 AM
Copy/Paste Automation of Multiple parameters noizgirl Pro Tools TDM Systems (Mac) 1 01-24-2005 10:54 PM
Copy/Paste Automation of Multiple parameters noizgirl Tips & Tricks 0 01-21-2005 03:46 PM
