Old 01-18-2022, 09:34 PM
basehead617 basehead617 is offline
Default End-of-day process
What is the recommended 'end-of-day' S6 best practice?
My guess would be leave all power on but Shift-FADERS OFF to darken board/disable faders?
I assume this increases the life of some components.
Old 01-19-2022, 06:26 AM
its2loud its2loud is offline
Default Re: End-of-day process
The S6 MTM has a sleep mode where everything goes dark after a bit when nothing is active.
Closing ProTools sessions and DADMan will remove any active faders.
Old 01-19-2022, 10:39 AM
EddieJones's Avatar
S6 sleeps displays and LEDs to save them and power. Generally speaking leaving electronics running (at the same temperature) prolongs life....but isn't very green
Old 01-19-2022, 11:09 AM
devinemke's Avatar
devinemke devinemke is offline
when leaving for the night, i always leave my S6 in "Screening Mode" (/Settings/System/Brightness/). then simply touch the MTM screen the next morning to wake it up.
Devin Emke
Audio Post Production
Saturday Night Live, NBC
Old 01-19-2022, 11:12 AM
creativecontrol's Avatar
Screening Mode - which can also be triggered via SHIFT + Faders Off on the numeric section of the Automation Module. I agree with Eddie. My S6 is usually up for several months without a shutdown.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 01-19-2022, 11:30 AM
Thank you - I’m rarely the last or first to touch it and I’ve always done Shift-FADERS OFF and was curious if that was even needed.
Can not save "because the process is being used by another process". luc-heuer Pro Tools 4 12-05-2021 01:51 PM
RX4 Batch process Reckless Erik Post - Surround - Video 24 09-11-2015 05:40 AM
Problem populating HD 4 accel + Process + Process Brandonx1 Post - Surround - Video 6 07-15-2010 04:40 PM
hd process and accel process in same machine? blumediaprojekt Pro Tools TDM Systems (Mac) 1 02-01-2006 07:51 PM
Next Process after mix? DaMixG 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-19-2005 07:51 AM
