I'm not the most technical with PT10 as far as MIDI/controllers go....
Recently bought the NanoKontrol2 and works fine with Ableton Live 8. PT10 however sees it as a MIDI input but doesn't see anything in the Peripherals area where the setup tell you to look for HUI device. Some people state it's under MAudio Controller....but I see nothing either way. Must be something I'm missing....any sugguestions...? (FYI, been through Korg's support process, they passed the buck like a hot potato once I told them it worked fine with Ableton) |
Is there any setup software with the Korg? Just wondering if it has a HUI mode.
HP Z4 workstation, Mbox Studio https://www.facebook.com/search/top/...0sound%20works The better I drink, the more I mix ![]() BTW, my name is Dave, but most people call me.........................Dave |
The NanoKontrol2 is supposed to have a HUI mode....
"Sometimes having limits keeps you sane ![]() |
There are drivers and the patch editing software.
The NanoKontrol2 does have an HUI mode called "Pro Tools mode" which is enabled by holding down two buttons upon plugging it in. Like I said. PT10 sees it as an input but the HUI Peripherals doesn't see it. I'm totally over this at the moment. LEGEND status to anyone who helps me find a fix. |
try looking under "M-Audio keyboard" in the midi controllers section of the peripherals dialogue.
I got a free nano-kontrol (the first one) with my pt9 upgrade and this is where it shows up. check this out: http://trikome.com/blog/2009/02/27/h...th-protools-8/ it most likely will work with your set up |
This has been tried. Doesn't work.
It's something to do with PT10 itself or the interaction between the two as I've been using the NanoKontrol2 in Ableton since I posted. This is probably one I'm just gona have to drop. Unless anyone's got a solution in the future. |
nanokontrol2 and pro tools express | hotpies | Third Party Interfaces | 1 | 09-03-2014 10:40 AM |
Korg nanoKONTROL2 | David2934 | Eleven Rack | 0 | 01-03-2013 12:58 AM |
Korg D3200 & Pro Tools 8 LE | stringsandkeys89 | MIDI | 1 | 10-21-2011 06:26 PM |
Anyone using Korg KP3 with Pro Tools? | davidman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 07-02-2009 02:32 PM |
how to connnect Korg R3 to pro tools le 7 | jigme | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-01-2008 11:26 AM |
