mbox 2 acting strange
Edit: Sorry, I screwed up and posted this in the wrong forum. If a mod would be so kind as to delete it that would be great.
I'm running PT 9 with a USB mbox2 on Windows 7 (i've got a separate drive for samples and project files). Everything has been working fine until a few days ago... Sometimes it recognizes that the audio card is acting weird and it won't play at all, other times it tries to play but all that comes out is sudden bursts of static every 2 seconds or so (it's a consistent interval). I can't get any sound out of any program anymore except the weird consistent static bursts (I've been trying iTunes and PT mainly). I've tried uninstalling and re installing the mbox2 drivers to no success. I've uninstalled and re installed PT and everything was back to working for a few minutes but then randomly (with a PT session open) it went back to the sporadic static thing and won't work again. I've done a search and I've seen things about random white noise, which was an issue I had occasionally with my old malfunctioning laptop and PT (same mbox), but this is a different sound. It's like the audio card is malfunctioning.. when I try to run PT with the failing audio, I can watch as the line struggles to move across the screen, as if it's waiting for the audio card to act. Another thing, before it stopped working all together, I was getting the "You are running out of CPU power" error when I was pretty sure I shouldn't have been (only a few plugins open when I used to be able to have much more). did I screw up by trying to use my mbox2 for regular default windows sounds? Is my mbox dying? Any help I could get would be very much appreciated. Thanks in advance. ***** Start of Report ***** -------------------------------------------------------------------------------- <<< Status >>> -------------------------------------------------------------------------------- < SiSoftware Sandra > Name: SiSoftware Sandra Lite (Eval) Version: 2012.01.18.10 Platform Compliance: x64 URL: http://www.sisoftware.co.uk E-Mail: [email protected] Twitter: http://twitter.com/sisoftwareuk Facebook: http://www.facebook.com/SiSoftware < SiSoftware Sandra > Copyright: Copyright © SiSoftware 1995-Present. All Rights Reserved. Registered Owner: Owner Registered Organisation: Unknown Licence Status: Free strictly for personal/educational use; 21 days trial for any other use. Licence Extra: You are on day %d of your trial period. Please see 'Help - Get More' for purchase details. < Environment > Host Name: Owner-PC0775 User: Owner Computer ID: {07761229-3F01-47BA-B169-09784911990B} Result ID: {39B05DA9-2221-4AED-B951-CFEB967C3091} Date: Sunday, November 27, 2011 @ 9:20:32 PM <<< Comments >>> -------------------------------------------------------------------------------- <<< Computer Overview >>> -------------------------------------------------------------------------------- < Computer > Workgroup: WORKGROUP Host Name: Owner-PC0775 User: Owner < Processor > Model: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz Speed: 3.89GHz Cores per Processor: 4 Unit(s) Threads per Core: 2 Unit(s) Type: Quad-Core L1D (1st Level) Data Cache: 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 (2nd Level) Cache: 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 (3rd Level) Cache: 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 16 threads sharing < Computer > Mainboard: Intel DP67BG BIOS: Intel BGP6710J.86A.2040.2011.0629.0142 06/29/ 2011 Bus(es): X-Bus PCI PCIe IMB USB FireWire/1394 i2c/ SMBus Multi-Processor (MP) Support: No Multi-Processor Advanced PIC (:Yes Total Memory: 8GB DIMM DDR3 < Chipset > Model: Intel Core (Sandy Bridge) DRAM Controller Front Side Bus Speed: 100MHz Total Memory: 8GB DIMM DDR3 Channels: 2 Memory Bus Speed: 2x 800MHz (1.6GHz) < Memory Module(s) > Memory Module: Super Talent SUPERTALENT02 4GB DIMM DDR3 PC3- 12800U DDR3-1600 (11-11-11-29 5-40-13-6) Memory Module: Super Talent SUPERTALENT02 4GB DIMM DDR3 PC3- 12800U DDR3-1600 (11-11-11-29 5-40-13-6) < Video System > Video Adapter: NVIDIA GeForce GTX 550 Ti (192 SM5.0 1.8GHz, 1GB 4.1GHz, PCIe 2.00 x16) Video Adapter: NVIDIA GeForce GTX 550 Ti (192 SM5.0 1.8GHz, 1GB 4.1GHz, PCIe 2.00 x16) < Graphics Processor > OpenCL GP Processor: NVIDIA GeForce GTX 550 Ti (192SP 4C 1.8GHz, 1GB 4.1GHz) Compute Shader Processor: NVIDIA GeForce GTX 550 Ti (192SP 1.8GHz, 1GB 4.1GHz) CUDA GP Processor: NVIDIA GeForce GTX 550 Ti (192SP 4C 1.8GHz, 1GB 4.1GHz) < Storage Devices > Seagate ST3500413AS (500.1GB, :466GB (C:) Seagate ST31000524AS (1TB, SAT:932GB (E:) PLEXTOR DVDR PX-L890SA (SATA:N/A (D:) DTSOFT BDROM (): N/A (F:) < Logical Storage Devices > OS (C:): 436GB (NTFS) @ Seagate ST3500413AS (500.1GB, SATA600, 3.5", 7200rpm, 16MB Cache) Storage (E:): 932GB (NTFS) @ Seagate ST31000524AS (1TB, SATA600, 3.5", 7200rpm) Optical Drive (D:): N/A @ PLEXTOR DVDR PX-L890SA (SATA150, DVD+- RW, CD-RW, 2MB Cache) Optical Drive (F:): N/A @ DTSOFT BDROM () < Peripherals > LPC Hub Controller 1: Intel P67 LPC Controller LPC Legacy Controller 1: T0 B4-73 Audio Device: ZOTAC International (MCO) 0BEEh Audio Codec: nVidia 0015h Audio Codec: 1 0001h Audio Codec: 1 0001h Disk Controller: Intel ICH8R (ICH8) SATA RAID Controller Disk Controller: Intel 6121 RAID Controller USB Controller 1: Intel Cougar Point USB Enhanced Host Controller #2 USB Controller 2: Intel Cougar Point USB Enhanced Host Controller #1 USB Controller 3: Intel Renesas Electronics USB 3.0 Host Controller FireWire/1394 Controller 1: Intel TSB43AB22 1394a-2000 OHCI PHY/Link- Layer Controller SMBus/i2c Controller 1: Intel ICH SMBus < Printers and Faxes > Printer: Microsoft XPS Document Writer (600x600, Colour) Fax: Microsoft Shared Fax Driver (200x200) < Network Services > Network Adapter: Intel(R) 82579V Gigabit Network Connection (Ethernet, 100Mbps) < Operating System > Windows System: Microsoft Windows 7 Home 6.01.7601 (Service Pack 1) Platform Compliance: x64 < Windows Experience Index > Current System: 5.9 <<< Processor Arithmetic >>> -------------------------------------------------------------------------------- < Benchmark Results > Aggregate Arithmetic Performan:104.81GOPS Dhrystone SSE4.2: 117.58GIPS Whetstone SSE3: 93.43GFLOPS Results Interpretation: Higher Scores mean Better Performance. Decimal Numeral System (base 1:1GOPS = 1000MOPS, 1MOPS = 1000kOPS, 1kOPS = 1000OPS, etc. < Windows Experience Index > Current Processor(s): 7.7 Results Interpretation: Higher Scores mean Better Performance. < Performance vs. Speed > Aggregate Arithmetic Performan:26.94MOPS/MHz Dhrystone SSE4.2: 30.22MIPS/MHz Whetstone SSE3: 24.01MFLOPS/MHz Results Interpretation: Higher Scores mean Better Performance. < Performance vs. Power > Processor(s) Power: 95.000W Aggregate Arithmetic Performan:1103.27MOPS/W Dhrystone SSE4.2: 1237.72MIPS/W Whetstone SSE3: 983.44MFLOPS/W Results Interpretation: Higher Scores mean Better Performance. < Benchmark Status > Result ID: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz (4C 8T 3.89GHz Turbo, 3.9GHz IMC, 4x 256kB L2, 8MB L3) Computer: Intel DP67BG Platform Compliance: x64 NUMA Support: No SMP (Multi-Processor) Benchmar:Yes Total Test Threads: 8 Multi-Core Test: Yes Cores per Processor: 4 Unit(s) SMT (Multi-Threaded) Benchmark:Yes Threads per Core: 2 Unit(s) Processor Affinity: P0M0C0T0 P0M0C1T0 P0M0C2T0 P0M0C3T0 P0M0C0T1 P0M0C1T1 P0M0C2T1 P0M0C3T1 System Timer: 3.31MHz Number of Runs: 64000 / 640 < Processor > Model: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz Speed: 3.89GHz Peak Processing Performance (P:62.26GFLOPS Adjusted Peak Performance (APP:18.68WG Cores per Processor: 4 Unit(s) Threads per Core: 2 Unit(s) Type: Quad-Core L1D (1st Level) Data Cache: 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 (2nd Level) Cache: 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 (3rd Level) Cache: 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 16 threads sharing < Memory Controller > Integrated in Processor: Yes Speed: 3.9GHz < Features > SSE Technology: Yes SSE2 Technology: Yes SSE3 Technology: Yes Supplemental SSE3 Technology: Yes SSE4.1 Technology: Yes SSE4.2 Technology: Yes AVX - Advanced Vector eXtensio:Yes HTT - Hyper-Threading Technolo:Yes < Performance Enhancing Tips > Notice 5008: To change benchmarks, click Options. Notice 5004: Synthetic benchmark. May not tally with 'real- life' performance. Notice 5006: Only compare the results with ones obtained using the same version! Warning 242: Dynamic OverClocking/Turbo engaged. Performance will not be consistent! Tip 2: Double-click tip or press Enter while a tip is selected for more information about the tip. <<< Processor Multi-Media >>> -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- ***** End of Report ***** |
Mbox 3 driver acting strange | Cartoonguy | FireWire & USB Audio Interfaces (Mac) | 0 | 01-23-2014 11:25 AM |
003R acting strange? | Holly73 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 12-16-2008 03:46 AM |
Need Computer Help, G4 Acting Very Strange! | johnjm22 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 08-28-2005 04:56 PM |
Help! MBox acting strange... | KDK Twelve | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-13-2004 03:44 PM |
HELP!! DIGI OO2 ACTING VERY STRANGE! | johnjm22 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 09-28-2004 05:00 AM |
