How to adjust overall length for mixdown?
Can anyone tell me how to remove the dead space at the beginning and end of a song? When I bounce my final mixdown to disk it has dead space at the beginning and end of the song, and I don't know how to remove it before I bounce it to disk. Any help would be greatly appreciated!
Re: How to adjust overall length for mixdown?
In the timeruler in the editwindow, you can select a part of your song. If you do that prior to choosing to bounce to disk, you will only bounce your selection. If you have a reverb or delay in your mix, make sure you select a little bit more to avoid the reverb being broken off....
What's that? - That's the machine that goes "pling". Bastiaan |
Thanks! You guys are WAY COOL!
you should probably have an editing program, like Sound Forge. you can trim your song, fade it out, do cool crossfades, mix pastes, etc. you can do this in ProTools, but programs ilke Sound Forge were built for this type of editing. or, you could just import your bounce into a new session and trim the way you want.
Jeremy Forbis |
a good free wav editor is GoldWave. it does all the basic stuff like trim, fade, volume, etc. great free utility...
i love my apple iPhone! |
Also, to shorten your overall session length, like when the song ends at measure 80, but you let it record & roll all the way to 200.
So, you want to shave that excess space off. 1.Click the 'Shuffle' Mode button. 2. In the Time bar, highlight going left to right, from the end of the song all the way to the end of the session (so the excess is all black). 3. Hit 'Delete'... that's it. [img]images/icons/wink.gif[/img] ~Roy
rh music |
Drawn MIDI note length only staccato notes, regardless of note length | kingofallwookies | Pro Tools 11 | 2 | 02-07-2014 07:10 AM |
Copied region length auto-adjust to paste location length? | greglawrence | Tips & Tricks | 4 | 10-23-2011 12:46 PM |
Fine adjust fader in edit window caput! command+adjust | crizdee | Pro Tools TDM Systems (Mac) | 2 | 12-09-2008 03:55 PM |
Mixdown - mixdown pitch shift problem | kakeneeditoo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-03-2007 03:38 PM |
Can I adjust the length of punch takes? | Mark_Jeangerard | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 10-18-2005 03:18 PM |
