When I open PT a problem surface
I am on Win10 and I am running PT 2022.4. My interface is Apollo Solo. A new problem has disabling me t0 record or mix. When open PT everything runs ok. But when I am trying to a apen a session PT says "The current playback engine does not support at the rate of 48 kHz". Has anyone had this problem? And how resolving it. Thanks.
Win11 Pro Intel i7-12700K @3,6GHz, RAM 32GB UAD Apollo and pre-amps, Pro Tools 2023 lots of plugins |
Re: When I open PT a problem surface
Windows is likely using your Apollo as the default sound device. Go to Control Panel-sounds and designate your onboard sound device as the default for Windows sounds so PRO TOOLS can have exclusive access to the interface.
Open PI preset from surface | Gregor B. | Avid S4/S6 | 19 | 04-25-2022 03:09 AM |
Profile surface VGA problem | yagga121 | VENUE Live Sound Systems | 8 | 08-23-2012 07:14 AM |
PT 6.4 Control Surface Problem | PatrickJ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-20-2005 04:37 PM |
Control Surface Problem | artvolk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-14-2005 08:21 PM |
CS-32 control surface problem | avanti | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-20-2005 10:48 AM |
