Old 07-19-2009, 03:28 AM
dkrz dkrz is offline
Exclamation Bug using "Save As" and Title-bar Path Menu
I often use the "Save As" function, which of course, puts the file you're currently working on in the new location. (as opposed to "Save A Copy In".)
Every so often, I need to Command Click on the file name in title-bar to double check were I am (the path of my current open session). This worked just fine in all previous versions of PT. Except in PTLE8...
This function is now broken. Even though the file does actually exist in the new (Save As) location, the title-bar path menu no longer reflects this. It continues to display the file's original path which is, in reality, no longer the active path. Hope this makes sense...
All my other applications that support this function continue to do this correctly, so it's not an OS thing. Maybe Digi can take a look at this bug? Thanks.
dk
www.dpksound.com
Old 07-19-2009, 03:38 PM
Default Re: Bug using "Save As" and Title-bar Path Menu
Hmm... guess no one's interested. Oh well...
www.dpksound.com
Old 07-19-2009, 07:03 PM
@ndy's Avatar
@ndy @ndy is offline
I never knew about the command click on the title bar trick. I tried it out on a "save as" session and you are correct. It must be a bug.
2012 Mac Mini i7 2.6Ghz, 16GB RAM, 250GB SSD, OS 10.8.4, 003R, PT10.3.4, Midi I/O and late 08 15" Macbook Pro 2.4GHz, 4GB RAM, OS 10.8.4, Mbox2, PT10.3.4
Title/Name confusion with "export clips as files" stargazer macOS 0 03-02-2014 11:05 PM
"cannot save "XXXXXX" because while translating I/O settings" tdawgg Pro Tools 10 14 10-26-2013 02:27 PM
Save as > "Could not 14404 because File or folder not found (-43) while opening "..." Elias Stiza 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-10-2012 07:06 PM
DAE error 9060, then "can't save error -50", then "can't eject drive" glankrudolph 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-17-2009 03:24 PM
"Newbie" needs help on "save" and "drives" Thomas C. Gass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-30-2001 11:43 PM
