Old 03-14-2009, 04:56 PM
digidesigner digidesigner is offline
Default why no dithering option on "export regions as files"?
I would love to see the dithering option added to "export regions as files".. Why must we export our mixdowns as 24 bit files an then import them into another application to dither down to 16 bit for a CD?
Old 03-14-2009, 05:20 PM
Drew Mazurek's Avatar
Default Re: why no dithering option on "export regions as files"?
Export Selected as files does dither. Always has.
www.drewmazurek.com
Old 03-14-2009, 05:27 PM
Ups my bad then. I have waves and digi ones installed at least, how can I choose witch is used?
Old 03-14-2009, 05:38 PM
I think it's in the Prefs.
www.drewmazurek.com
Old 03-15-2009, 04:37 AM
Ok so now I am at my computer and all I see in the prefs about dithering is "Use AudioSuite Dither" If that's it then I definitely do not want to have 16 bit dithering on my every audiosuite processing and it would be a PITA to go and change this in the prefs for every move.
So I still think it would be nice to have a drop down menu of available dithering methods and settings at the export audio dialog.
Old 03-15-2009, 10:43 AM
Export does dither - but there's no choice of which.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Title/Name confusion with "export clips as files" stargazer macOS 0 03-02-2014 11:05 PM
PT 8.1 audio "hits" or "pops" when i open files from PT7... djoeyd77 Pro Tools TDM Systems (Mac) 1 10-31-2009 03:59 AM
Structure - what does "Monolithic" mean as it pertains to "part" files? Jared_TL Virtual Instruments 2 12-07-2008 03:37 AM
If I "Remove Unused Regions" after "Consolidate", track won't play? el biciclista Pro Tools TDM Systems (Mac) 10 04-02-2003 10:17 AM
"Export Selected Regions" and Dither DigiTechSupt Pro Tools TDM Systems (Mac) 13 12-18-2002 04:14 PM
