hardware not recognized
I know it has been discussed on this thread:
http://duc.digidesign.com/showflat.p...fpart=1#876908 but it went cold and I still don't have an answer. I just did a clean uninstall of PT 6.9 (and then 6.9.2 just to be safe) and then did an install of 6.9 and then 6.9.2 but PT still won't recognize my mBox. Launching PT gives me the "connect hardware and click 'OK'" prompt and the Digi Core Audio app doesn't recognize that anything is connected. The mBox IS powered up by usb but not recognized. Also, I have tried different USB ports and I've trashed the preferences as suggested in the above thread. Any help would be greatly appreciated. thanks much, -c G5 dual 2gig os x 10.4.2 PTLE 6.9.2 |
Re: hardware not recognized
If you've tried that Mbox on all of the usb ports on your computer and it's still not working, AND you've gone thru all of the troubleshooting suggestions in the sticky at the top of the forum, then you're left with only a few options:
1. See if you can locate another computer where you can install PT and see if the Mbox works there. 2. See if you can get another Mbox to test on your computer. Your dealer would be a good place to accomplish both of these tests. If none of that is possible or both have negative results: 3. Call DigiCS and get an RMA Good luck. |
I just tried to load PT 6.9 on my wife's iBook and it treated the mBox the same way as above. Digi Core Audio calls it an unsupported device and PT won't recognize that it's connected.
For giggles, can someone who has an mbox chime in? ALL of the LEDs on my mBox are illuminated all the time (except for the 2 red "peak" notifiers and the phantom power (48v) notification. is that normal? |
thanks again, -c |
Hardware not recognized......... | Ryan Butler | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-28-2009 09:24 PM |
002 rack hardware not recognized | Joey joe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 08-20-2008 03:02 PM |
Hardware not recognized | tribase | Pro Tools TDM Systems (Mac) | 2 | 09-21-2006 08:05 PM |
002 hardware not recognized | lynnk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-30-2006 06:15 PM |
M box Hardware not recognized on my PC | Monching | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-31-2005 07:34 PM |
