Followup Question
I am helping my brother with his setup of a Motu MKII 2408 connected via Adat to the Digi 002.
Here is the setup Adat out of Motu to Adat in of the 002 Motu clock set to Internal 002 set to external Recording vocals to a track in Pro Tools shows activity, waveform etc the problem is we can hear everything else in the session except the vocals even thoug the meters are moving could someone help with this problem? Thank you in advance |
Re: Followup Question
Is the problem when you are actually recording, or just have the track armed? If the latter, control-K. Turns off auto-input monitoring.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
I am able to record, but i cant hear while I am recording or during playback, i am able to hear the other tracks in the session that were recorded using just the 002, the vocal were recorded with a preamp connected to the Motu, so the vocal came in thru the motu, and i cant hear it during playback, ,maybe there is some setup with the motu and the 002 that i am missing
Weird. Let me see if I understand right. You record on a track, it shows the waveform and the meters show normal activity, but there's no audible sound from that track? It's output is assigned the same as tracks you can hear? What happens if you:
Switch to internal clock Close Pro Tools Disconnect the Motu device Launch Pro Tools Make a new session at the same sample rate and bit depth Import the audio from that track into the new session?
Is the output of the vocal track set to something other than "Stereo 1-2" or "Analog 1-2"?
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
the output of the Vocal track is set to the same output as the other tracks
What we've got to do is find out if the file being recorded actually has normal audio in it. That's the point of importing it into a different session without the Motu connected. If it plays normally, then you may have stumbled on a major bug. If it doesn't, then the problem is more likely in the record signal chain; i.e., the audio's not really getting to the track to start with.
Ok I will try that when i go to my brother's place tonite,
btw thanks guys for your help I really appreciate it, i will update once i try this later |
fruity loops in pro tools question...not regular rewire question | nutrinoland | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-23-2010 12:39 PM |
quick question - Mbox Mini question - i forget | JRup | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-18-2009 02:55 PM |
General Venue Automation Question - (Maybe dumb question) | TwoPort | VENUE Live Sound Systems | 5 | 12-21-2007 02:41 PM |
Noisy Mbox followup | boboski | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-26-2005 07:53 AM |
vocal mic techniques, followup | badperson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-18-2003 10:07 AM |
