Xpand! Midi Channel
I use LE 7.3.
I have a midi track and a virtual instrument track with Xpand! assigned to it. When I try to send the midi track's output to Xpand!, the only option showing for Xpand!'s midi channel is 1 though I REALLY need it to be any other channel than that. I cannot find a way to change Xpand!'s midi channel. I'd really really appreciate it if someone could help me add or change Xpand!'s midi channel. Thanks. |
I believe a given instance of XPand! (like the one you have in the instrument track) uses exactly one MIDI channel (no more, no less). To my knowledge, there is no way to change it. FYI, XPand! is not multi timbral. That is, it cannot receive MIDI data from multiple different MIDI channels and play multiple parts. It can receive from multiple MIDI tracks, but all MIDI data will go to XPand! on one MIDI channel. |
The easiest way would be to instantiate another Xpand!. Though, if you're saving on system resources, print the respective Xpand! Parts.
filosofem |
don't use a MIDI track
Use an inst track only Change the MIDI input (at the very top of the mixer track) from "ALL" to what ever single channel you need..
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
Xpand! Midi Channel
This if for live recording of a band.
There is a keyboard player I want to fire Xpand samples when he plays but when the drummer plays, his electronic drums also fires Xpand. The drums only work on channel 1 so I need Xpand to be assigned to another. Xpand only pulls up as channel 1. HELP!! I don't get it. |
Xpand! Midi Channel
When addng another Xpand virtual track, protools just calls it Xpand2 but the midi channel still #1
"Change the MIDI input (at the very top of the mixer track) from "ALL" to what ever single channel you need."
There is no midi channel changing option on a virtual instrument track. Where are you talking about about so I can look if I'm mistaken? |
As previously described, at the very top of the instrument track, is the midi input selection. (Expand the mixer track view to all if you're not seeing this) Select only the keyboard to be the input. Drums normally come in on midi channel 10, so use another instrument track for drums, selecting drums as the input. On the drum/inst track, do not assign it to Xpand.
What is your midi interface and setup?
OSX10.6.8, 1st gen Power Mac, PT8.0.5, Mbox2 |
can I use more than one Midi ch. with Xpand? | Alex Rodriguez | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-25-2012 12:29 PM |
XPAND and MIDI keyboard, please help!! | dstar917 | MIDI | 3 | 06-06-2009 11:30 PM |
Midi Files using Xpand! | jay stewart | Pro Tools M-Powered (Win) | 3 | 08-21-2008 12:33 PM |
MIDI and Xpand! | rc86mike | Virtual Instruments | 5 | 03-09-2007 08:13 PM |
2 MIDI Input Tracks Output to Same MIDI Channel | altemir | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-05-2005 03:20 PM |
