Old 08-16-2008, 11:42 AM
rkaynan rkaynan is offline
Default Xpand! Midi Channel
I use LE 7.3.
I have a midi track and a virtual instrument track with Xpand! assigned to it.
When I try to send the midi track's output to Xpand!, the only option showing for Xpand!'s midi channel is 1 though I REALLY need it to be any other channel than that.
I cannot find a way to change Xpand!'s midi channel. I'd really really appreciate it if someone could help me add or change Xpand!'s midi channel.
Thanks.
Old 08-16-2008, 01:50 PM
gdugan gdugan is offline
Default
Originally Posted by rkaynan View Post
I use LE 7.3.
Thanks.
I'm not exactly sure why you would need a MIDI track and an instrument track. An instrument track is a MIDI track combined with an Auxiliary track.
I believe a given instance of XPand! (like the one you have in the instrument track) uses exactly one MIDI channel (no more, no less). To my knowledge, there is no way to change it.
FYI, XPand! is not multi timbral. That is, it cannot receive MIDI data from multiple different MIDI channels and play multiple parts. It can receive from multiple MIDI tracks, but all MIDI data will go to XPand! on one MIDI channel.
Old 08-16-2008, 03:40 PM
Default
The easiest way would be to instantiate another Xpand!. Though, if you're saving on system resources, print the respective Xpand! Parts.
filosofem
Old 08-16-2008, 03:52 PM
flommer flommer is offline
Default
don't use a MIDI track
Use an inst track only
Change the MIDI input (at the very top of the mixer track) from "ALL" to what ever single channel you need..
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 08-17-2008, 06:37 AM
This if for live recording of a band.
There is a keyboard player I want to fire Xpand samples when he plays but when the drummer plays, his electronic drums also fires Xpand.
The drums only work on channel 1 so I need Xpand to be assigned to another. Xpand only pulls up as channel 1. HELP!! I don't get it.
Old 08-17-2008, 06:40 AM
When addng another Xpand virtual track, protools just calls it Xpand2 but the midi channel still #1
Old 08-17-2008, 06:45 AM
Default
"Change the MIDI input (at the very top of the mixer track) from "ALL" to what ever single channel you need."
There is no midi channel changing option on a virtual instrument track. Where are you talking about about so I can look if I'm mistaken?
Old 08-17-2008, 07:01 AM
musicalavtech musicalavtech is offline
Default
As previously described, at the very top of the instrument track, is the midi input selection. (Expand the mixer track view to all if you're not seeing this) Select only the keyboard to be the input. Drums normally come in on midi channel 10, so use another instrument track for drums, selecting drums as the input. On the drum/inst track, do not assign it to Xpand.
What is your midi interface and setup?
OSX10.6.8, 1st gen Power Mac,
PT8.0.5, Mbox2
Old 08-21-2008, 11:18 AM
Default
I want to thank you for fixing my issue. I didn't realize that was in "instrument" selection on the pull down menu on both the mixer and edit screens. That's where I was able to change the midi channels!!!
can I use more than one Midi ch. with Xpand? Alex Rodriguez 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-25-2012 12:29 PM
XPAND and MIDI keyboard, please help!! dstar917 MIDI 3 06-06-2009 11:30 PM
Midi Files using Xpand! jay stewart Pro Tools M-Powered (Win) 3 08-21-2008 12:33 PM
MIDI and Xpand! rc86mike Virtual Instruments 5 03-09-2007 08:13 PM
2 MIDI Input Tracks Output to Same MIDI Channel altemir 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-05-2005 03:20 PM
