Old 06-28-2007, 05:55 AM
blueviewrecords blueviewrecords is offline
Default Question on stereo tracksnormalizing versus compression etc.
I have just recorded my first mulitrack demo 8-10 tracks per song.
My questions are:
1. Can I bounce a stereo track to mono?
2 What is the best method for mastering a track with lots of variation in volume?
I want the volume to be consistent until time for a solo.
My other question is, when normalizing and compressing what is the typical db range to work in?
Also, How do I analyze a track to see where the volume range falls for each track?
Thanks. I'm not that great at finding new things in PT.
Scott Patrick
Blueview Records
iMac 2.66 GHz
1GHz system bus
Mac OS X v10.5 Leopard
2GB DDR2 800 SDRAM
320 GB SATA
ATI Radeon HD 2600 Pro
FW 400 & FW 800 port
Old 06-28-2007, 08:18 AM
jre3132 jre3132 is offline
Default Re: Question on stereo tracksnormalizing versus compression etc.
thats quite a bit to be unsure of. You might try reading through the reference guide to find new features and Google some terms (mixing, mastering, etc.). As far as your questions:
  • 1. Can I bounce a stereo track to mono?
    yes, just choose those settings. If you're trying to use it in the same session you might try bussing to a track and recording. It might be a little easier.
    a mastering limiter would probably be the best. I wouldn't worry about normalizing, since the limiter will bring the track up louder than the normalization process.
    you can hold apple and click the volume indicator below the fader in the mix window to show the loudest volume in a song.
Mac Pro 3.7 Quad Core Intel
Mac OS X 10.13.2
PT Ultimate HDX 2019.10
64GB RAM
HDX I/O 16x16 Analog
HDX I/O 8x8x8
Voices versus Stereo tracks HB1978 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 01-11-2009 11:18 AM
Stereo versus Mono Question Elton Hyland 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-10-2007 01:24 PM
mono versus stereo delay uses cary chilton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 02-15-2007 06:38 AM
Stereo versus Mono - something I found and liked IntelDoc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 07-06-2005 07:52 AM
Compression on the way in versus plug ins Dopamine Tips & Tricks 25 09-24-2004 08:12 AM
