Old 10-02-2018, 03:13 AM
alonper alonper is offline
Default Waves as DSP plugins on Ultimate 2018.04 HDX
We just upgraded from HD to HDX running PT ultimate 2018.04.
We are trying to undestrand, suddenly after the upgrade we cannot run Waves AAX plugins as DSP plugins, they are available only as native plugins...?
And, we cannot add native plugins during record enabled, only after inserting a DSP plugin in the chain.. why is that?
Thanks in advance
Old 10-02-2018, 03:44 AM
Sardi Sardi is offline
Default Re: Waves as DSP plugins on Ultimate 2018.04 HDX
Waves never made AAX DSP plug-ins.
Did you upgrade from a TDM system?
Old 10-02-2018, 03:50 AM
Yes we had the Pro Tools HD with Avid HD io's..
Is there a way to insert native plugins on a track while being on record mode? It bypassed .
Old 10-02-2018, 06:24 AM
dtmprod dtmprod is offline
It was that way with TDM as well. Trying to use native in record mode automatically goes into bypass. Like you mentioned, using a DSP plugin first 'fixes' that.....
Old 10-02-2018, 06:28 AM
jsvalmont jsvalmont is offline
You can run Waves plugins as AAX DSP if you have a DigiGrid DLS. It uses an AAX DSP shell plugin to talk to the SoundGrid server that is actually running the plugin.
Old 10-02-2018, 06:32 AM
So what is the point if you can insert native plugin , but only after inserting a DSP plug?
Old 10-02-2018, 08:16 AM
YYR123's Avatar
YYR123 YYR123 is offline
Originally Posted by alonper View Post
Thanks in advance
It was a horrible thing when Waves didn't support AAX-DSP. I have moved on from waves products for that reason. I do use maybe 2 or 3 of their plugins still but for the most part i don't use most of what i own.
These are really good guys that do support AAX-DSP plugins. not all of their plugins are AAX-DSP but the channel strips, eq's and comps are for sure.
https://www.plugin-alliance.com/
these guys are awesome as well. I believe almost 100% of their lineup is AAX-DSP. Great prices too, couldn't say that about Waves TDM.
http://www.sknoteaudio.com/wp/
Daniel
Old 10-02-2018, 09:34 AM
Raoul23 Raoul23 is offline
McDSP are kick arse for AAX-DSP plug-ins !!
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 10-02-2018, 01:20 PM
JFreak JFreak is online now
and so are Sonnox
Old 10-03-2018, 03:50 AM
Will Russell's Avatar
Will Russell Will Russell is offline
I had an HD system with Waves TDM plugins and Waves stated publicly that they would write for AAX-DSP. So I upgraded to HDX only to find that Waves changed their minds.
I too have now moved on from Waves. Honestly, I'm still angry about it. I'm never giving them money for their own DSP. Never.
BTW- I invested in a lot of SoftTube plugins because of their AAX-DSP support and they have also recently announced that they will not be doing any more AAX-DSP, so I'm phasing them out as well.
McDSP, Sonnox, Metric Halo, PluginAlliance, SKNote all make great plugins.
Will Russell
Electric Wilburland Studio
https://linktr.ee/wilburland
M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock
M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS
HTML code is On
ProTools 2018.4 Ultimate and macOS Mojave BillDog793 Pro Tools 2018 121 03-07-2019 04:37 AM
2018.7 Ultimate Slow Load stanonbass Pro Tools 2018 14 08-27-2018 12:54 PM
PT 2018.4 Ultimate bugs ? Glazik Pro Tools 2018 26 07-10-2018 11:56 PM
Protools Ultimate 2018 quits unexpectedly cristtiah Pro Tools 2018 3 06-26-2018 02:25 PM
S6 M10 v3.5 works with PT ultimate 2018.4 ? vudoo Avid S4/S6 3 05-30-2018 03:06 PM
