Old 01-13-2004, 01:54 AM
emery emery is offline
Default tab to transient
can someone please tell me how to tab to transient? im trying to replace a snare track one at a time. im certain that there is a keyboard shortcut or some way to skip to the next peak, or transient.
thanks in advance
matt
Old 01-13-2004, 02:25 AM
PT2GO PT2GO is offline
Default Re: tab to transient
In the upper left of the edit window (just under the shuffle,spot,etc modes) you have to turn the tab to transient button on. Then you can drop your cursor into the snare track and hit the tab key. It'll jump to each hit.
Jerry
Nashville, TN
Old 07-28-2004, 11:33 PM
bH101 bH101 is offline
Default Re: tab to transient in reverse?
is it possible to go tab trans in reverse direction?
also, is there a menu selection and/or a gui control for cursor placement? i dont recall changing any settings, but now it keeps jumping to the beginning of the song regardless of where i put it.
any links to good tutorials on editing ? thanks!
G5 Dual2.0 OSX 10.3.4 Digi002R PTLe 6.4? Logic 5,6,7 Reason 2.5
G4 Powerbook1.5 OSX 10.3.4 Digi MBox Ptle 6.4
Old 07-29-2004, 06:27 PM
RobMacki RobMacki is offline
I use the "L" ":" """ "P" keys. You can sample replace w/ rt hand on those keys and left hand on the "V" quite quickly. (kinda reminds me of playing scales or arpeggios)
[/QUOTE]
[/QUOTE]
I can't remember what that is, make sure "Insertion Follows PB" is not on and check prefs.
Old 07-30-2004, 02:04 PM
toolskid666 toolskid666 is offline
if you're not using commands focus - 'alt+tab' will tab backwards!!
Old 07-30-2004, 08:58 PM
parak parak is offline
option - tab will tab in reverse, which to me seems to yield better results for some reason in tab to transient.
When you say cursor placement do you mean insertion point, or where playback starts? Check that you didn't turn on pre-roll (cmd+K) this will hapeen if you option - click somewhere. Also check "Link edit and timeline selection" under operations. It's button is right next to the tab to transient button.
Old 08-08-2004, 02:02 AM
ameyerson ameyerson is offline
If you have your keyboard commands on and hit "n" by accident the curser will toggle between play from stop and play from origional point. A really bad place to put that quick key
Algorithm difference between tab to transient and option + tab to transient? taiga_with_a_pen Tips & Tricks 2 02-13-2010 10:35 AM
Tab to transient JonMitchell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-07-2005 11:18 AM
tab to transient LuisB Tips & Tricks 0 08-22-2005 05:00 AM
Tab to Transient BigRay Tips & Tricks 2 06-07-2005 04:27 PM
Tab To Transient eddierojas Tips & Tricks 1 04-11-2004 08:26 PM
