Old 12-30-2012, 09:41 AM
enzo2025 enzo2025 is offline
Default Pro Tools 9 freezes whole system
Hi, I've had a Digidesign 003 Factory and now I own a Fast track C600 along Pro tools 9 original.
Both audio hardware caused exactly the same problem. Even with two different PC's over Windows 7 64 bits Service Pack 1!!
One was Pentium Quad Core and now I own a brand new i7, but I changed completely all of the components, two different computers at all with different audio hardware and I got the same EXACT problem.
It just freezes everything and I have to do a hard reset. I've uploaded a video so you can see what the problem is (if you turn up the volume, the sound trtrtrtrtrtrtrtrtrtrtrtr is how pro tools stays when it freezes the whole system.
https://dl.dropbox.com/u/22495357/13...3a8a926b7c.MOV
FYI, Windows is working perfectly, and Cubase is working perfectly too, just Pro Tools...
I hope that any of you has had it and solved it, or at least, you could help me out because I'm going nuts and I am very angry
Thanks mates I am really looking forward to a reply.
Old 12-30-2012, 10:17 AM
Default Re: Pro Tools 9 freezes whole system
Help us Help You - READ THIS Before Posting!
Look for this link in the upper section of this(and every) DUC page. Nobody can help without details. That link will explain how to do a Sandra report(and just do the newer computer for now).
Old 12-30-2012, 02:55 PM
Sorry I thought that you'd look into my profile where I have my specs. I'll do a report as you say and post it here. Thanks for you reply :)
Old 12-30-2012, 03:00 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default
After the Sandra - try trashing the prefs also
New session and see what that does
Daniel
Old 12-30-2012, 03:42 PM
That's what you meant (I hope so!)
SiSoftware Sandra
Computer
Model : OEM
Chassis : Desktop
Mainboard : ASRock Z77 Extreme6
BIOS : AMI (OEM) P1.40 04/18/2012
Intel vPro : 8.00.02.1410
Total Memory : 15.9GB DIMM DDR3
Processors
Processor : Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz (4C 8T 3.4GHz, 3.4GHz IMC, 4x 256kB L2, 8MB L3)
Socket/Slot : FC LGA1155
Chipset
Memory Controller : ASRock Core (Ivy Bridge) DRAM Controller 100MHz, 2x 8GB DIMM DDR3 1.6GHz 128-bit
Memory Module(s)
Memory Module : Kingston 9905403-500A01LF 8GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5)
Video System
Monitor/Panel : BNQ BenQ RL2240H
(1920x1080, 21.7")
Monitor/Panel : LG L226W
(1680x1050, 22.0")
Video Adapter : NVIDIA GeForce GTX 660 (5CU 960SP SM5.0 1.08GHz, 2GB 6GHz 192-bit, PCIe 2.00 x16)
Graphics Processor
OpenCL GP Processor : NVIDIA GeForce GTX 660 (960SP 5C 1.08GHz, 2GB 6GHz 192-bit)
Compute Shader Processor : NVIDIA GeForce GTX 660 (960SP 1.08GHz, 2GB 6GHz 192-bit)
CUDA GP Processor : NVIDIA GeForce GTX 660 (960SP 5C 1.08GHz, 384kB L2, 2GB 6GHz 192-bit)
Storage Devices
Seagate ST2000DM001-9YN164 (2TB, SATA600, 7200rpm) : 2TB (D:)
Crucial M4-CT128M4SSD2 (128GB, SATA600, 2.5", SSD) : 119GB (C:)
Logical Storage Devices
Almacen (D:) : 2TB (NTFS) @ Seagate ST2000DM001-9YN164 (2TB, SATA600, 7200rpm)
Reservado para el sistema : 100MB (NTFS)
Hard Disk (C:) : 119GB (NTFS) @ Crucial M4-CT128M4SSD2 (128GB, SATA600, 2.5", SSD)
Peripherals
LPC Hub Controller 1 : ASRock Panther Point LPC Controller
LPC Legacy Controller 1 : T0 C3-33
Audio Device : ASRock Panther Point High Definition Audio Controller
Audio Device : ASUS 0E0BControladora de High Definition Audio
Audio Codec : nVidia GeForce 6800 [NV40.1]
Serial Port(s) : 1
Disk Controller : ASRock Panther Point 6 port SATA AHCI Controller
Disk Controller : ASRock Asmedia 106x SATA Controller
USB Controller 1 : ASRock Panther Point USB xHCI Host Controller
USB Controller 2 : ASRock Panther Point USB Enhanced Host Controller #2
USB Controller 3 : ASRock Panther Point USB Enhanced Host Controller #1
USB Controller 4 : ASRock Etron USB 3.0 Extensible Host Controller
FireWire/1394 Controller 1 : ASRock VIA VT6308 1394 OHCI Controller
SMBus/i2c Controller 1 : Intel ICH SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Peripherals
Media Player : Microsoft Shared Fax Driver (200x200)Apple iPhone (28.49GB)
Network Services
Network Adapter : Broadcom NetLink (TM) Gigabit Ethernet (Ethernet, 1Gbps)
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1)
Platform Compliance : x64
Windows Experience Index
Current System : 5.9
Thanks mate.
(By the way, with this computer, 5.9 points ?!?!)
Old 01-01-2013, 02:24 PM
I've tried that but I get the same behaviour Sometimes it takes up to 20 seconds, other times maybe 1 hour....is quite random and very very annoying. It's true that trashing prefs MIGHT make Pro Tools crash a little bit later.
Old 01-01-2013, 02:50 PM
Default
Start by doing all the systems optimizations, do every last one, and following the standard troubleshooting steps described under the "help us help you" link on this web page.
I do not get why Avid is still requiring approvals for sone posts. Make sure you are just trying to submit a standard Sandra report (look at others posted all over DUC). You *may* be trying to post something too large.
Darryl
Old 01-01-2013, 03:35 PM
Exclamation Re: Pro Tools 9 freezes whole system
Summary:
Memory Module : Kingston 9905403-500A01LF 8GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) [x2]
Storage Devices
Operating System
Fast Track C600
Old 01-01-2013, 03:37 PM
Darryl
Yep, I did everything out there (even from the BIOS). I also trashed Pro Tools preferences... I don't understand why, with a brand new computer, and another audio hardware (before Digi 003) keeps happening.
Thanks for your time and your effort in helping me
Old 01-01-2013, 04:16 PM
Originally Posted by enzo2025 View Post
Summary:
Storage Devices
Operating System
Fast Track C600
No, that is too little info, as I said like the reports everybody else posts here. Like for random example --http://duc.avid.com/showthread.php?t...ghlight=Sandra. Is that what you are trying to post before and was blocked for approval?
Thanks
Darryl
Pro Tools 10 FireWire freezes system on project(s) startup Bendik Jensen Windows 1 06-01-2013 02:51 PM
Pro Tools 9 randomly freezes my system. Windows 7 shimmyshimmy Windows 9 09-20-2011 12:45 PM
System freezes when using Komplete 7 and/or Maschine as a plug-in with Pro Tools tfa 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-30-2011 03:47 PM
System freezes when using Komplete 7 and/or Maschine as a plug-in with Pro Tools tfa 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-30-2011 09:16 AM
odd system freezes pedro803 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 05-20-2003 10:27 AM
