10.3.2 won't extract
I recently installed 10 on my Dell N4010/8gb ram/Win 7, and decided to update to 10.3.2. My 10 install was from the DVD. I downloaded the update as a full install from Avid. It won't expand.
Did an uninstall prior to the download. Tried the download 2 times. What's the issue? |
Re: 10.3.2 won't extract
If you have the download in a folder called " pro tools" try moving it to a different directory.
Thanks for your reply, Dave. I found the PT installer within a PT folder, expanded, but when I run it, it can't complete. A message I get in the middle of the install process states I did not run the setup, which means some necessary components may not be installed. Or something to that effect. Well, I tried running the Setup application first, but it won't run. I thought it was not expanded, which prompted my post. Apparently it is, but it just does not run.
Sorry, I usually use Macs. However I had it running fine on this machine, installed from the DVD. I don't understand why upgrading is such a PITA. |
Sounds like maybe it is still expecting the d: installer to run.
Did you uninstall all the Avid software and drivers using the "programs and features" control panel? Turn off your interface before uninstall. I would reboot after uninstalling If you left a driver the new installer might be confused. Also, I always run the installers as an admin. |
No progress since yesterday. I will try your suggestions, and go through it again, thanks.
This is getting ridiculous. |
cant extract download?? | vin7 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 11-09-2010 04:34 AM |
Extract Timing | gdfrey | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-11-2007 01:22 PM |
OT: Audio Extract from a DVD | Jerry K. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-23-2004 11:30 PM |
OSX and CD Extract | imported_Américo | Pro Tools TDM Systems (Mac) | 0 | 11-04-2002 02:28 AM |
How to extract audio from DVD | Brickdog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-23-2001 09:35 AM |
