Audio Drop Outs when PT is chasing LTC
When my PT 8.01 is slave-synced to timecode (LTC received through SYNC i/o interface) I have small dropouts in the digitally recorded audio tracks (usually STEMS, sometimes up to 10 minutes long, no big start/stop or punch in/out action). This occurs whether I am recording via AES/EBU as well as using ADAT Lightpipes. I usually record around 30-40 tracks simultaneausly.
These dropouts are usually around 10-200 Samples long, enough for a dirty POP When I closely examine the waveform I see it continues exactly after the dropout. So it is not like a part of the waveform is missing but there is just no data during the drop out in the timeline - and after that the waves continues normally. So no data is gone - but it is in a wrong position in the timeline (on sample level) after the drop out. This can happen once or 20 times during the recording of a stem audio track. I don't know whether the problem is connected to Timcode (LTC) issues or a WordClock problem. PT is the WordClock Master (Sync i/o), the interfaces are synced via Loopsync. Generally asking: when recording long stems digitally while PT is slave synced to LTC: does PT CHASE the LTC ? Meaning does it update the positional reference all the time, only sometimes or just the moment the recording STARTS and from there on ALL OTHER syncing to the incoming digital signals is only done via WordClock ? How do WordClock and LTC interact during digital recording ? I appreciate your expertise, thanks ! |
Re: Audio Drop Outs when PT is chasing LTC
First most assurably have a timecode framerate mismatch
On the sync io on the slave when chasing is the lock/resolve LED blinking If yes Fast = incoming code is faster than session Slow = incoming code is slower than session Quick fix is to set position and ref both to LTC while chasing ( slave ) If this resolves it find your TC mismatch Are you using video in the session ?
http://www.studio-techservices.com าำ [email protected]mMitch Berger Tech Services We service ALL Avid products no Problem HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around inquiry using link above Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear |
No (I guess not ;-) ALL set to 25 FPS (Europe standard)
I don't have a Sync HD, only Sync i/o, but also the HD seems to only have a "locked" LED, nothing like "resolve"... But this LED does not seem to blink (I'll keep an eye on it) Quote:
No, the LTC master is a second, MAC-based workstation with sequencer software (Logic pro) Appreciate your help & tips, we seem to narrow it down. Still the biggest for me is whether PT, when being WordClock master and LTC slave CHASES the LTC or not during the digital audio recording process.... Does it only set a "start" marker and then wordclock (internal) sync only or does it "update" the TC position during rec (like every frame or 10 frames or whatever...). I have been wondering about this since a long time, if anybody knows what is REALLY happening during audio rec with ext LTC sync... give me enlightment |
When you say "PT is WC master", did you actually slave the Logic system to the PT WC? If not itดs not really surprising that you are encountering drop-outs due to clocking errors.
Either clock PT to the incoming AES signal or make sure you are clocking the TC master to the same WC. I donดt know your application but why not simply export the file from Logic instead re-recording it in real time in PT? Just wondering... regarding your other question: LTC just give positional trigger sync. After that a DAW runs on the given clock to main to speed. It does not slowly re-chase like an analog tape machine. Which is why studios have a common house sync for all units to avoid digital glitches or sync issues.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Dear Frank
thanks for the answers ! Unfortunately Logic needs to be TC master, 'caus slaving Logic is a nightmare and never really worked ...at least in the digital domain. In Midi and tape-days it actually did work OK, but that was on frame-level, not KHZ / WC / Sample related digital timing- and clocking stuff...) I'll try Wordclocking ProTools to AES. I just thought as I have a couple of PT-interfaces hooked (96 i/o, 192 i/o, Sync i/o) I'd better make sure they are running on their own clock (in this case the sync i/o being the loop-sync master) rather than from a PCI-card stuck in the other (logic-)mac and it's WC out.... Why I don't transmit the files (good point ) is because Logic doesn't have a command to bounce each track one by one automatically. In my songs I sometimes have like 50 tracks. Offline bouncing sounds worse (YES, even if little people believe it ) than online boncing in logic. So to have 50 tracks discretely bounced online one by one and then "pulled over" by hand, plus alligning them in PT - it would take like 5+1 minutes x 50 tracks = 5 hours. With my current setup I press Play on Logic an REC in ProTools and after 5 min I have 50 tracks as 50 audiostemfiles ready to mix in PT. BUT... it works only 6 out of 7 days... and that's why I post here and hope to gather additional info how to possibly turn this into 7/7 days... Thanks for the info reg continous sync ...Good to know that even when PT is a LTC slave it only positions itself ONCE at the start and then calculates the positions internally (probably by calculcating some algorhythm with SampleRate and Tempo of the session...sounds reaonable ) Thankx for your advice and any additional thoughts from anybody... |
You missunderstood. You can go either way regarding TC chase. The important point I was asking was wether you're sending the PT WC to your logic converter?
both rigs need to run to the same WC to avoid glitches. either that or you need to run PT as a WC slave from one of the digital ins. My suggestion would be that you WC slave PT to your logic rig when Logic is the TC master. This can either be done via WC or you sync PT to one of itดs digital inputs (ADAT, AES or whatever). Don't run them on independent clocks otherwise digital glitches are almost guaranteed and they might even drift apart over a longer time. PT "calculates sync internally" (you said). Sync is maintained via the converter clock which is why the most important thing is to put everything on the same clock. TC will only tell PT where to start playing/recording. frank.
HD 10 HDX Audio Drop outs | stanonbass | Pro Tools HDX & HD Native Systems (Mac) | 0 | 06-10-2013 01:42 PM |
Audio Drop Outs on Some Channels | Caatalyst | Pro Tools 10 | 8 | 12-18-2012 04:48 AM |
HDX Audio drop outs on all HW Inserts | Carl Lie | Pro Tools 10 | 9 | 01-12-2012 03:52 PM |
ROSETTA 800 AUDIO DROP OUTS ANYONE? | jeffjuliano | Pro Tools TDM Systems (Mac) | 1 | 04-01-2005 10:17 AM |
Mystery Audio Drop Outs | cpunthank | Pro Tools TDM Systems (Mac) | 0 | 11-07-2003 04:17 PM |
