Uad 1 test scores Tests @ 44.1k + 48 k
well to all who are interested I tested these plugins in pro tools
44.1 k 16bit 9- 1176 19- La2a 23-1176SE 36 - Cambridge 48k 16 bit 15 - La2a 6- 1176 21- 1176 se 36- cambridge 10- cs1 ( this was the limit not because of cpu but card memory ) 9 -realverb pro 10- pultec unforunatly the fairchild and the pultec pro I did not test but the fairchils is like an 1176 maybe heavier this is for One card |
Re: Uad 1 test scores Tests @ 44.1k + 48 k
Very interesting. Thanks for sharing your detailed info. I'm not clear on the architecture of those cards, whether or not it "spills" over into the computer's cpu when it runs out of card-DSP.
When you would "hit the wall" in your tests, was that wall defined by just the card's limitation, or was the wall hit when the card + the computer couldn't take it? You know what I mean? Is it... Scenario A: 9 realverb pros + most of the rest of my CPU (65% or so?) still available for my other plugs, processing, etc. - or - Scenario B: 9 realverb pros + [nothing] I know that the wrapper takes a little (???) of the native cpu power, but if it's more like Scenario A, that makes it very appealing. Thanks again, - Proxy
G4 dual 1ghz QS (1.5gig RAM) / OSX v10.3.9 / HD4 / AD8K / PT v6.9 |
Re: Uad 1
ok yeah sorry I could have added more info
My card was set at 85 % cpu load so I probably couldve pushed more if set to 99% but I like stabilityso 85 % is the highest I will go ( not that 99% is unstable I dont know I never tried ) And as for the host cpu It gets hit differently for different plugins The 1176 SE for example had no cpuload on the host ( or close to none ) and some made it go to half way and some filled the card memory before cpu I believe 1176 was the most host cpu heavy though Oh and the pultec is the same at all sample rates because it ALWAYS operates at 96k or something like that check UA webpage for more info on that so I hope that clears it up a lil for ya guys feel free to ask some more questions if you have any or I left something out thanks |
Re: Uad 1
Did you do this test with the VST adapter from UA that was designed for the UAD
or was this done with the VST to RTAS adapter that FXpansion made prior to UAD requesting one for their card. Thanks. FatBelly Slim
FatBelly Slim Oh no, not the sprinklers again. |
Re: Uad 1
Hey,
Thanks Mersis, this is very helpful. So you're saying that once you loaded, say, nine 1176s (in 44k), that was pretty much it for your whole setup plug-in wise? You couldn't have 9 1176s, plus 2 Ren-Verbs or something like that? - Proxy
Re: Uad 1
I own the mackie card so yes I had to also buy the VST2RTAS from FX pansion
and these tests were performed so that no CPU was left on the card or as close to it as I could get in these plugin intervals . so you might be able to get another se 1176 on these tests maybe I also stated that these tests were done at 85 % so setting it to 99% mightn increase results more but you may jeopordize stability I dont know Im a conservative in this sense thanks for the positive feed back guys i really love these plugins cant wait to try the pultec pro as the pultec really rocks ! |
PS - if there are any other tests you guys want me to do I will be happy to do it
I thought of doing this because I think Im one of the first to get this working Or at least I dont see many posts about it and someone emailed me with this request so i thought I might as well post it here thanks again |
Re: Uad 1
Thanks again for the continued play-by-play.
Sorry for the need of overclarification, I just want to make sure I'm getting what you're saying. Thanks for your patience, - Proxy
Re: Uad 1
the 85 % refers to the UAD 1 card setting
and no problem Im trying to be thorough but you cant remember everything off the top of your head can you ? thanks for your input / inquaries And im not a DR so I dont have any patience ( get it hahahaha ) |
This a separate question.
Did the origianl Mackie you purchased come with more plugs than new one offered by UA now, I mean the higher priced card they offer. And I would like to know if PT can control fader automation on your GS3 board from Allen & Heath, if that is the one with automation. Thanks. FatBelly Slim
Scores for drummers | Whitwirt | Avid Scorch (iOS) Forum | 0 | 02-07-2013 03:59 AM |
Scores won't download | Bubblyalex | Avid Scorch (iOS) Forum | 2 | 12-22-2012 02:56 PM |
Exporting Scores? | play4theworld | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-03-2011 07:31 AM |
D-verb test scores for MacBook Pros 2010? | SixChurchStreet | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-24-2011 01:15 PM |
How can I print scores? | tamasdragon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-12-2009 03:42 AM |
