Old 06-25-2022, 01:57 PM
Cayce Cayce is offline
Default Shut Off Selection High-Light
When I choose a memory location selection, I'm getting this distracting high-light of the selection range on all tracks. Happens also when I manually select a playhead range. Is there a way to turn this off? Just a bit annoying.
Thanks.
File Type: jpg Screen Shot 2022-06-25 at 4.47.04 PM.jpg (48.2 KB, 0 views)
Pro Tools Studio, 2023.3.0
Mac OS: Ventura 13.4
System: Mac Studio 2023, Apple M2 Ultra, 128GB Unified Memory
2TB Internal SSD
Apple Studio Monitor, 27"
3 External Monitors: 27", 27" & 65"
Apollo X8P Mixer Interface
PreSonus 32R Mixer Interface
Old 06-25-2022, 02:22 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Shut Off Selection High-Light
Thanks.
One way around it is to make the selection on the ruler bar such as the Meter bar when creating the memory location. That way only the ruler gets highlighted when the memory location gets recalled and not the tracks.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 06-25-2022, 02:46 PM
nednednerb's Avatar
nednednerb nednednerb is offline
Depending on your purposes, you could try making the Memory Location by 'marker' then choose to apply the Zoom setting.
Therefore, recalling the ML doesn't select a range of audio, but does show the desired spot and zoom level. Your cursor would always be at the start.
I might ask, why are you using "Selection" ML but seemingly don't want the selection of tracks? If you do require time to be selected recalling the ML, then the other option, selecting a ruler instead of the clips might be better for your purpose. (You could for instance just hit the semicolon a few times to navigate to the track you do want that time selected.)
Sent from my Pixel 6 Pro using Tapatalk
___
>> me: nednednerB //
||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music //
||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 //
||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock //
||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR
||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts //
Old 06-26-2022, 05:02 AM
The ruler approach did the trick. Thank God for the collective brain of this forum... a person could spend a hundred years discovering all the tricks hiding in the nooks and crannies of this Pro Tools labyrinth.
That's a really good question, and makes me realize I was doing the whole ML timeline selection a bit wrong. I've always made that selection in the playhead lane which would—obvious to me, now— select all tracks. If I set that selection in the individual track, I get only that track selection highlighted, which could be useful. So I learned two things here: (1) how to control highlighting on ML selections, and (2) that no matter how many years I've been immersed in PT, there will always be events that will humble me back down to "newbie" status.
You guys are the best. Thanks!
2TB Internal SSD
Mbox 3 High Sierra 10.3.4 Blinking Blue Light nickthap FireWire & USB Audio Interfaces (Mac) 4 01-17-2023 04:03 PM
003 rack is not connecting. Blinking green light. no HOST 1394 light. ccgascity1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-14-2011 12:41 PM
003 Rack Host light doesn't light...pt crash Kourquie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-03-2010 09:07 AM
Just bought a Mbox 2 mini, usb light doesnt light up/installation stops progressing? DjRybe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 12-27-2009 05:55 PM
1394 Light not WORKING!!! light not coming on at all HELLLPP Shizzle408 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-24-2009 03:42 PM
