PT 10 Export WAV---Larger File Size
For years, I've been exporting 24:55 programs as 16bit 44.1 Stereo WAVs, always resulting in a file size of 263,719, 156 bytes. After upgrading to Pro Tools 10, those same 16bit 44.1 Stereo WAV files are now 278,207,248 bytes. Can someone wiser than I help me understand why?
Re: PT 10 Export WAV---Larger File Size
If you're upgrading from Pro Tools 7 or below, the difference is going from 8-bit to 16-bit waveform overviews embedded in the wave files. That lets you see more detail of the waveforms when you zoom in.
I upgraded from v9 to v10. Very odd.
PT10 exports WAVs with a header problem, see here:
http://duc.avid.com/showthread.php?t...ght=wav+header Greetings, Thierry
http://www.a-sound.com/ |
Thank you Thierry. I hope this is something Avid addresses soon.
Cheers. |
same bump for you ... changing the Bwav standard is not he way forward ... is the Cat away ? because the Mice are playing around over there at Avid
Pro Tools 10 added support for RF64 format.
There is, indeed, a "JUNK" chunk as defined in the official spec to make switching between normal WAV and RF64 a seamless operation. The spec is here: http://tech.ebu.ch/docs/tech/tech3306-2009.pdf See section 3.5 on page 9. The JUNK type chunk was added to the original RIFF/WAVE specification by Microsoft about 20 years ago.
Matt Peterson Avid Audio |
Matthieu Bourque PT Ultimate 2022.10 on macOS 12.6.1 |
Greetings, Thierry
Looks like this data "chunk" has been fixed in 10.3.5...or at least the "junk chunk" is now smaller.
mp3 export doesn't show correct file size til another export done | obidon | Pro Tools TDM Systems (Mac) | 0 | 12-09-2010 01:13 PM |
How to export to a wav file? | lonlonmilklover | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-05-2006 08:42 PM |
How do you export an omf file???? | NEIGHTD | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 03-01-2006 11:04 AM |
Larger Minimum File Sizes?? | simonjbinks | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-11-2002 07:57 AM |
quadruple file sizes larger than they should be?! | DeafinONEear | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-28-2002 09:22 AM |
