4dB drop in output, am I missing something?
I might not know enough about this topic but this is what's happening:
I put in a signal generator and set it's level to 0dB, the Master Fader level is 4dB lower and the signal gen is the only thing running. Shouldn't it be exactly the same level?! What am I not getting here in all my amatuerity? Thanks in advance for help! |
Re: 4dB drop in output, am I missing something?
pan law?
not awake fully yet...maybe missing something...
nikki k Eagles may soar, but weasels don't get sucked into jet engines. On the other hand, you have different fingers. |
Yeah, I thought about the fact that a mono signals level might be a little higher than an "equally loud" stereo level or whatever. I assume that's what you're talking about. So I created a stereo signal gen and of course it matches levels. I had never known or though of that situation but I guess it makes sense.
Thanks! |
if you create a mono track with pan (routed to a stereo bus or output), the level on the stereo-bus or output will be 3dB higher when fully panned left or right. this is pefectly normal for PT.
frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Missing Output Channels | Sadie Tango | Pro Tools 10 | 0 | 09-16-2013 12:15 AM |
Missing AAX and RTAS in drop down menus | orangedog | AAX Plug-ins | 10 | 05-13-2013 11:23 AM |
BurnIT output massive DB drop to Tape help | SamuelAdams | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-20-2006 09:41 AM |
6.4.1cs2 Output levels still drop upon reopening | Tim R. | Pro Tools TDM Systems (Mac) | 9 | 02-15-2005 05:21 AM |
How to drop in replacement audio into empty (missing) regions? | c-post | Post - Surround - Video | 8 | 06-07-2003 03:19 AM |
