Old 05-09-2024, 08:00 AM
BCnSTL's Avatar
BCnSTL BCnSTL is online now
Default PT 2024.3.1 - Sonoma 14.4.1 - unresponsive AGAIN
So frustrated.
Something changed and now my Sessions will load but as soon as I try to do *anything* I get the beachball-of-death. PT goes unresponsive and I have to force-quit.
Yes yes. I'll do the remove-all-plugins hassle again. But this time, only to export stems because I've finally had my fill of wasting hours of precious hard-to-find time fighting my DAW.
I have 1 computer and don't have the luxury of freezing a working system in amber. Oh well. I love PT, when it works, which isn't often enough.
2023 M2 Pro - MacBook Pro 16 -16GB RAM - 1TB SSD.
macOS Sonoma 14.5
PT Studio 2024.6 Native.
Life is like an Analogy.
Old 05-09-2024, 08:20 AM
JFreak's Avatar
JFreak JFreak is online now
Default Re: PT 2024.3.1 - Sonoma 14.4.1 - unresponsive AGAIN
Go rogue and install latest beta of 14.5 -- in here works much better than release version of 14.4.1
Janne
Old 05-09-2024, 08:51 AM
BScout BScout is offline
That's the usual sign of Pro Tools having trouble talking to your audio interface. So check your audio interface and its drivers.
Pro Tools Ult 2024.6, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface ProS1 x 2, Fire Max11 x 2, Dock, iPad Air5 Mac Mini 14,12, 12 core, macOS 13.6.7RAM 32GB, SSD 4TB, GPU 19 coreQNAP TVS-872XT 148TB TB3
Old 05-09-2024, 11:13 AM
Eric Lambert's Avatar
I have a Lynx Aurora (n) which about once a month decides to go on the fritz. There's no visual sign that it's not functioning properly, it simple doesn't respond to PT and CoreAudio in the normal ways. A simple power cycle brings it back online.
I mention this because, yes, it was the cause of problems similar to the OP's. That very first time it happened I had no idea that it was the interface and I checked just about everything else. That was half a day's work wasted. Repaired in 10 seconds.
Old 05-09-2024, 01:05 PM
BCnSTL's Avatar
Good suggestions - thank you.
I'll try power-cycling the audio interface. If that doesn't work I'll (re)enable Beta OS updates. if that doesn't work? We'll see.
This keeps happening & I'm so tired of the constant struggle to just make incremental progress on the handful of songs I coax along.
First World Problems, I suppose.
macOS Sonoma 14.5
Old 05-09-2024, 04:10 PM
I hope you can figure out what's tripping it up. Not to rub salt into a wound but to offer encouragement: PT 2024.3.1 and OS 14.4.1 has been one of the most stable combos in recent memory. I did have some issues but deleting the plugin cache (and resetting the interface as mentioned) took care of that.
Old 05-09-2024, 07:04 PM
BCnSTL's Avatar
Interface reset WORKED!
I have never had to do that before but huge thank-you for the tip.
macOS Sonoma 14.5
Old 05-10-2024, 10:51 AM
Glad it worked out, and hopefully it won't happen again but if it does you'll know what to try.
MacOS Sonoma gnjlee macOS 332 06-07-2024 01:44 PM
Plugins don't work in Pro Tools 2024.3.1 (Mac, Sonoma 14.3.1) Pangolino Pro Tools 8 05-27-2024 01:11 PM
GetTrackList command still returns an empty array here - Pro Tools 2024.3/SDK 2024.3 GRT Pro Tools Scripting SDK Toolkit 6 03-19-2024 01:11 PM
When will Sonoma be supported on PT? eniigma Pro Tools 42 01-22-2024 11:04 PM
Mac OS Sonoma crashing PT bonkmp Pro Tools 8 12-26-2023 05:41 PM
