Question about cpu usage and plugins
This is kind of a noob question but it would be very helpful for me to help allocate my resources in my sessions when they're getting full, to know which tracks/plugins to disable first etc., if necessary:
Do plugins suck cpu juice from the second they're plugged in, or only specifically where there is audio passing through them on the track? i.e., say I have a digirack compressor inserted into a drum track (where audio is being played consistently throughout the whole song), and then I have another of the same compressor inserted into a lead guitar track where there is only audio during the guitar solo (once in the whole song). Hypothetically, given the compressor settings are the same, are the two plugins using the same amount of juice? I would think the one on the drum track is using more since more audio is passing through it. And for that matter, another question. Do plugins suck more juice the more you use the effect? i.e. if I've inserted an eq on a track and I'm sucking out say 9-10db of midrange, is that using more juice than if I were just shaving off 1 or 2 db? Thanks in advance!
iMac 21.5" (2017) Intel Core i7 3.6GHz, 1TB SSD, 32GB RAM PreSonus Quantum 2 interface Mac OSX 10.15.6 Catalina 1 G-Drive Pro 4 TB 2 G-Drive 6 TB ProTools 2021.3.1 Melodyne 5 Soundtoys Bundle 5.3.2 Omnisphere 2.6.2 Massey L2007 Superior Drummer 2.3.2 Komplete 13 Ultimate |
Re: Question about cpu usage and plugins
It can differ from plug to plug. In my experience, for EQ, there is no difference between audio/no audio, nor does it use any more power when boosting/cutting a lot than a little/none. But then, EQs don't use much to start with. For some compressors, maybe a little more when actively working but not much more, if any. Some multi-band compressors might suck a little harder when all bands are actively compressing than when none are. A plug with a lot of detailed graphic motion in its window, such as those that include an FFT analyzer, will use more (graphics) power when the window open than when it's not.
Where you really get the difference is with VIs. A VI that is playing notes will use more CPU than one that doesn't, and every extra note being played at once generates a new instance of the instrument in RAM, thus taking lots more power.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
Ah yes, the VIs. That's where I probably should've started my example, as I use a lot of them.
So if I understand you right, if I'm playing a triad chord (3 notes at once) on a VI synth, it's using 3 times more power than if it were just a single note lead?
Yep. Open the System Usage window and watch it while you play notes. Highly educational.
Thanks again.
Plugins drive CPU usage too high | therealnoelmason | Windows | 10 | 06-30-2013 08:19 PM |
CPU usage holding off when samples plugins loaded | alfredogzz | RTAS & TDM Plug-ins | 6 | 04-03-2013 09:10 PM |
Plugins,strange cpu usage, please help me | Alessio alecos | macOS | 0 | 10-15-2012 01:23 AM |
Constant 9128 CPU Usage error even on one track, no plugins at 2048 buffer | AdamWathan | Pro Tools M-Powered (Mac) | 1 | 02-04-2010 07:47 PM |
CPU Usage low... close some plugins??????? | sambora68 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-10-2004 09:33 AM |
