AudioSuite/Consolidate SLOW
Here is an interesting test. Create a new mono audio track, make a lengthy selection(say around 1 hour) get the audio suite signal generator tool and hit render- time how long this takes, it should only take a few seconds. now with that new region selected hit render again to create another new file over top of the first. This time the render will take significantly longer (aprox double) WHY?
Now try this - Create a 5.1 channel track, set the interleaved mode to OFF and repeat the above test, your results should be about the same but in general six times as long because of the extra files. Now try again with Interleaved turned ON- you will be waiting for many minutes for your render. Again WHY? this behaviour is also evident when using "consolidate" something I did all the time in PT8 now takes ages to process. Am I Missing something here or is this a result of the new audiosuite render with handles feature? thanks in advance My System MAC Pro 2009 6gig OSX 10.7 PTHD 10.3.2 6 Acell TDM cards |
Re: AudioSuite/Consolidate SLOW
I am having the exact same issue with hd 10.3.2
Anyone reply with a fix? OSX 10.7.5 2.8 GHz Quad-Core Xeon 9 GB 667 MHz DDR2 |
No Answers Yet. However:
Increasing my ram seems to have made a difference. I took my machine up to 32 gig and set a 24 gig cache. Once a session has cached the timeline, processing seems to speed up. R |
Consolidate/Audiosuite bug | Tim R. | Pro Tools 10 | 1 | 09-12-2012 01:29 PM |
No waveform after Consolidate, AudioSuite | iyejeff | Pro Tools TDM Systems (Mac) | 2 | 01-16-2007 06:03 AM |
slow audiosuite compressor | Simon Hill | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-08-2002 02:25 PM |
Audiosuite / Consolidate Digital Noise Help! | Burt | Pro Tools TDM Systems (Mac) | 0 | 07-05-2002 04:01 PM |
AudioSuite very slow... | jeronimo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 07-06-2001 09:02 PM |
