Old 05-31-2005, 03:38 AM
Steve Sarzi Steve Sarzi is offline
Default BCF2000 usb communication problems
Hi, I use an Mbox and PT LE 6.7 on a Win XP laptop and I want to use my BCF2000 as controller in Hui mode.
In peripherals menu I've selected Hui as midi controller but midi ports for BCF has seen as [emulated].
PT give me a communication error and it seems that PT can only receive commands (if I move a fader on BCF it moves on mix windows) but cannot send anything (the bcf remains with b-hui written and nothing moves).
I think this is a problem with this "emulated" drivers, but is the only driver I see.
Thank you for any help
Bye
Steve
Old 05-31-2005, 09:31 AM
gerax gerax is offline
Default Re: BCF2000 usb communication problems
Hi (o dovrei dire ciao...)
I guess you have to update the firmware on the BCF unit, as I saw several posts on this forum regarding this same problem (or similar). I undertand there were some issues with the controoler list, once it gets updated it semms to work OK.
I think Bastiaan has solved some of them, maybe doing a search for the BCF200 keywork will bring those threads up.
Hope this helps
L.G.
Old 05-31-2005, 10:55 AM
Bastiaan Bastiaan is offline
I have it working on ptle 6.4. As i recall there where some issues with the HUI-protocol in 6.7 and 6.9.... Make sure you have the correct drivers for the HUI in ptle.
What's that?
- That's the machine that goes "pling".
Bastiaan
BCF2000 and PT10, Win7 32bit. Recieve communication only. Sidhu Windows 3 06-12-2012 04:58 AM
Problems using BCF2000 with 7.4 zv yoda Pro Tools M-Powered (Mac) 1 03-04-2009 06:15 AM
Pro tools 7.3 and Bcf2000 in HUI --> problems yanos 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 04-10-2007 12:11 AM
Problems installing my BCF2000 serraris 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-27-2006 08:36 AM
BCF2000 Problems with ProTools 6.1.2 nsmenke 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 03-06-2006 11:24 AM
