Old 10-19-2009, 03:55 PM
prsjohnny prsjohnny is offline
Exclamation Not getting sound from my guitar!!
I'm not sure if this is the proper place to post this but I might as well try...
I've just done a fresh install of PT LE 7.1.2 on my Xp machine. Using the Mbox 2 Pro as my interface.
I'm getting audio with the demo session and by playing .wma's on my comp but I can't get any sound to come from my guitar.
Here's exactly what I'm doing...
I create a new session. Then, add a mono instrument track (but have also tried the other types as well). After that, I open the mix window and have tried ALL the inputs. Still, I cannot get any sound to register. It's like I have nothing plugged in.
FYI, I've never worked in PT before so please bare with me. Thanks!
Old 10-19-2009, 05:00 PM
sw rec sw rec is offline
Default Re: Not getting sound from my guitar!!
Do you have the input on your mbox switched to "instrument"? A guitar pickup is a VERY VERY VERY weak signal, so if that input is in 'line' or "DI" mode, you won't see a significant level.
We'd "bare" with you but bare is another word for naked. Let's opt for "bear."
Old 10-19-2009, 05:09 PM
JMS40 JMS40 is offline
You need to create an Audio track, not an Instrument track. (Instrument tracks are used with Midi/Synth pairs.)
You need to make sure that the input of the Audio track is set to match whatever physical input your guitar is plugged into.
Good luck.
"Then, add a mono instrument track"
That is incorrect. You should record your guitar to an audio track. Instrument tracks are for combining midi and soft synths(easy to get confused on new terminology). Create an audio track, chose input(1 or 20 plug in your guitar and pluck it. Click on the RECORD button so it flashes red. With the GAIN knob up and the DI input selected on the Mbox, you should see the track meter jumping. If you don't, review. If you DO see the meter move with signal, try to record a few strums. If you get no signal while the transport is running, then you may have selected INPUT ONLY MONITORING(Alt-K with keyboard focus turned on). You can check under the options menu for that as well. Once you get recording to work, then you will need to deal with the MIX knob. Generally, you would turn the mix knob halfway and MUTE the recording track(it still records). The MIX knob will balance your new signal with the tracks that are already recorded.
Old 10-19-2009, 09:23 PM
Thanks, problem solved. Now, I'm trying to mic my amp and all I have is a condensor microphone and an xlr to 1/4" cable. I'm not getting anything. Any ideas?
Old 10-19-2009, 09:45 PM
You have to use a balanced cable for a condenser mic. Either an XLR to XLR, or an XLR to 1/4 TRS (Tip-Ring-Sleve). You'll also have to make sure the Phantom Power button is depressed.
Old 10-19-2009, 10:14 PM
And unless I'm mistaken, the phantom power is ONLY on the XLR jack, not the 1/4" so it HAs to be an xlr cable period.
Old 10-20-2009, 06:56 AM
That is correct.
Old 10-20-2009, 01:38 PM
Wow! Thanks, that's such a relief. I was worried I might have to buy a new mic. Thanks a lot, fellas!
Make a guitar sound like a bass guitar carterisgod41 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 12-17-2011 01:36 PM
Thin guitar sound Ghostcage 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-15-2005 06:43 PM
Help With Guitar Sound xxRAiNxx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-10-2003 04:09 AM
Real bass guitar...Midi bass guitar... what to you put on em to make em sound great ? Jorge442 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 22 09-05-2002 11:41 AM
I cant get the guitar sound I want..... Trash Man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 07-28-2000 10:07 AM
