No sound on plugin input.
I use 8 LE on Windows 7 with Mbox Micro. My session is about 25 tracks. Everything is just fine until I insert a plug-in somewhere. Then the sound stops suddenly. After restart PT starts playing my tracks for a wile but with many glitches and then stops. I can fix this by removing almost all of the plug-ins. Sometimes it is the compressor that causes this behavior, sometimes is another one.
My session is on external eSata drive. Has anyone experienced such a problem? Thanx! |
Re: No sound on plugin input.
Posting a Sandra report might help get more advice. In any case, with Windows 7, you should be running 8.0.5(but I am not sure it will solve your problem). The Sandra report can point out hardware issues.
Help us Help You - READ THIS Before Posting!
Thanx! I am exactly on 8.0.5. I will post a report to see what will happen.
Problem solved. I started the session with Shift key pressed to load it with inactive plug-ins. Then I reloaded them and everything is just fine.
That usually means some plugin needs to be updated
MIDI input display plugin/program | chantler | MIDI | 0 | 07-31-2006 02:59 PM |
PT6.1 Stereo Aux Input plugin not recorded | mibo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 07-19-2003 01:37 AM |
Which Plugin to use to get rid of small sound booth sound? | andrej770 | Pro Tools TDM Systems (Mac) | 8 | 08-17-2002 08:04 AM |
Mbox sound input in Apple Sound Control | denbee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-24-2002 12:08 AM |
sound manager / sound input / 001 | lsr | Pro Tools TDM Systems (Mac) | 1 | 12-14-1999 01:58 AM |
