Old 02-12-2004, 07:48 AM
karldrei karldrei is offline
Default Setting up microphone on DIGI001
My condensor mic is connected to the microphone input at the front of the DIGI001, with phantom power on.
When I try to record I get quite low input levels (gain control on DIGI001 wide open) and it seems that it is only recording in mono, thoug I am recording on a stereo audio track.
Am I doing something wrong here, or is this just normal?
Old 02-12-2004, 08:01 AM
IntelDoc IntelDoc is offline
Default Re: Setting up microphone on DIGI001
1 mic = MONO unless you are using a stereo mic, which it sounds like you are NOT.
Try a MONO track....
Try a different cable. Make sure it is a good one...
Try the other Pre... Compare...
Good luck!
-Doc
MONUMENT SOUND
MONUMENT SOUND ON YOUTUBE
Monument Sound Facebook
"Changing how people hear music one track at a time"
Old 02-12-2004, 04:00 PM
Joe Evans Joe Evans is offline
Make sure that the pad on the Digi001 is off and also that the pad on the mic (if it has one) is also off.
--joe
Old 02-12-2004, 04:11 PM
optymusblu optymusblu is offline
make sure the -db is released out on the front of the interface
Learning,learning,and more learning!
THANKS TO THE DUC!
****OptymusBlu****
Old 02-12-2004, 04:15 PM
Aussie169 Aussie169 is offline
Yes, that is the PAD mentioned above
Old 02-12-2004, 07:05 PM
where02190 where02190 is offline
You need two mics to record in stereo, stereo is two tracks, one left one right.
Confusion when it comes to setting up a microphone Tastypants Getting Started 3 12-06-2013 07:14 PM
Setting Up The Microphone leecappella Pro Tools SE and Essential (Win) 1 10-24-2010 12:09 AM
Microphone Problems With Digi001 Craiger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-06-2005 07:33 PM
Setting up Pro tools 5.1.1.330 with the Digi001 ca jaccob79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-11-2004 07:24 AM
Setting up G4 for digi001 PTLE new kid in town 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 05-21-2002 12:26 AM
