Value of wiring PFL/AFL
Hi guys,
We're about to join the D-Control club and I can't wait! Right now I'm finalizing the XMON wiring with our tech. For conventional studio work, I can't work out what I gain by giving up a pair of outputs for the solo bus. Plus it uses more DSP. I appreciate in a live situation this would have uses but in the studio? I'm sure I'm misunderstanding something valuable about this feature so please enlighten me. PFL and solo in place appear to be the same thing to me. I assume most of you users have wired this in? I mean, it's only two outputs. Thanks,
Cool & Informative Video Tutorials from Groove3 |
Re: Value of wiring PFL/AFL
AFP = After Fader Listen = post fader, pre panning SIP = Solo In Place = post fader, post panning not the same thing as all
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
One use for AFL/PFL that we use regularly is for monitoring various mixes/stems during a multi-deck layback
eg when we are laying back a final to 1/2 on digi and an M+E on 3/4 plus various splits on a DTRS if you have all the mixes coming back into your session on aux inputs you can solo them without affecting the mix. It also saves you having to solo-disable all your stems/submixes within your session if you just want to be able to solo individual tracks |
Thanks Wheresmyfroggy. I get it now and I'll definitely wire it in. Seems totally worth it.
Not quite Craig.
PFL = Pre Fader Listen = pre fader AFP = After Fader Listen = post fader, post panning SIP = Solo In Place = post fader, post panning AFL and SIP are identical except that AFL is non-destructive and uses a seperate solo bus, whereas SIP uses the mix bus and is destructive. You can imagine for broadcast guys SIP will disturb the main feed (CLM - career limiting move) so they need a seperate bus. Music guys have no need to change the path of solo'd channels and want to ensure that it sounds precisely the same as when it's in the mix. PFL also uses the seperate solo bus. Quote:
Wiring up a studio, please help | rocksripley | ICON & C|24 | 1 | 11-21-2013 01:19 PM |
192 aes/ebu wiring | bengineer | Pro Tools TDM Systems (Mac) | 5 | 07-23-2007 12:05 PM |
AES wiring | RobMacki | General Discussion | 2 | 01-27-2006 05:07 PM |
US Plug wiring? | poppy | Pro Tools TDM Systems (Mac) | 2 | 08-17-2004 02:08 PM |
wiring 101 | badperson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 03-09-2004 01:38 PM |
