Help with latency on drum plug ins
Hi protools people, me again!!
I have been experimenting with using limiting (maxim) on the drum aux's to try and tame some of the peakiness of the drums and to bring out a bit more of the room sound, it definitely livens up the drum sound whilst reducing the peaks but can anyone provide some insight into the how I should tackle the latency this introduces. Do I need to nudge the drum tracks back to compensate for the 1024 sample delay that is shown on the channel indicator of the track with maxim on it or is there another way to fix this. I am using the (dual Stereo Aux) parallel compression technique with another aux for some reverb. I have only put maxim on the un-squashed drum aux but this seems to introduce some minor phase difference vs the squashed drum aux. Maybe I shouldn't be using a limiter at all or maybe I should put maxim on the other drum aux too - I dunno but it does sound better....Any advice welcome. Thanks
002R, PTLE 7.3, P'book G4, 1.5Ghz, OSX 10.4, 1 Gig Ram |
Re: Help with latency on drum plug ins
I ended up nudging all the drum tracks forward 1024 samples to make them exactly where they were before using the maxim limiting. It sounds like a lot of fiddling about but it has made the drum tracks a bit wetter and less peaky - a big problem with many of my past mixes. Thanks for your reply though and thanks for your other post on eq info at wikipedia. Good stuff. Stew
Simplest way to keep two tracks in phase with each other when doing the parallel compression thing: simply place the identical plugins on both tracks (aux´s) and bypass them on one track. This will introduce the same latency on both tracks. Of course, it will use more cpu.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
[QUOTE]
Simplest way to keep two tracks in phase with each other when doing the parallel compression thing: simply place the identical plugins on both tracks (aux´s) and bypass them on one track. This will introduce the same latency on both tracks. Of course, it will use more cpu. [/quote Thank for your reply, yes you are right this does fix the latency/phase issues on the parallel compression Aux's. But what concerned me most was that the drums as a whole are now out of sync with the other instruments (in particular the bass) - I know it's only 1024 samples and prolly isn't noticeable but it concerned me enough that I ended nudging the drum tracks forward, just to be safe. On a lighter note - I have now cracked the 100 posts barrier on the DUC. I must be into this stuff to have hung around so long....thanks to everyone on the DUC for helping me over the past 2 years!!!!!!!!! It's a great forum.
Im getting latency using drum triggers. How can I fix this | phatbeatstudio | Pro Tools 10 | 1 | 07-27-2012 06:40 AM |
adding latency with drum replacement | T.Glaze | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-29-2010 02:30 PM |
V-drum to Midi to Audio Latency | propower | Pro Tools TDM Systems (Mac) | 14 | 05-06-2008 02:51 PM |
Drum tracking latency | stormpro | Tips & Tricks | 2 | 06-25-2005 04:11 AM |
Latency and drum tracking | spicyitaliano | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 22 | 07-21-2003 12:01 AM |
