Old 02-15-2011, 09:26 AM
armadacd55 armadacd55 is offline
Default MC Control Not working in Pro Tools M-Powered 8 Under HUI
Heya,
I am having an issue with my MC Control, I cant seem to get it working in pro tools No matter what I do.... Any help would be greatly appreciated.
My setup is as follows:
Euphonix MC Control going directly into a Mac Pro setup On a static IP address as recommended by the manual. EuControl 2.5.5 (2.5.6 no longer supports HUI) and Pro Tools M-Powered 8.0.4.
The computer sees the desk and I can control Logic flawlessly but for some reason the surface wont work in Pro Tools.
I have setup Pro Tools and the ports in the Euphonix preference pane and assigned the ports in peripherals dialog box in PT but the surface does not engage....
I have tried the troubleshooting tips in the FAQ section on Euphonix website including a permissions repair followed by re-setting the HUI setup and removing conflicting MIDI drivers, I have even done a clean install of OS X and PT.
Again any help would be greatly appreciated.
Thanks in advance.
Tom
Old 02-15-2011, 03:24 PM
DigiTechSupt's Avatar
Default Re: MC Control Not working in Pro Tools M-Powered 8 Under HUI
Can you tell me *exactly* the settings you have in Peripherals>MIDI Controllers, as well as in the Euphonix System Preference panel?
Avid Audio Tech Support
Support FAQ
Old 02-15-2011, 05:09 PM
Hey there,
Thanks for the reply, it seems to be working now.... Under the euphonix preference pane I had the Eucon launch services turned off. What I would do was turn the surface on, launch EuControl, when it had loaded and gone green, i would then launch the DAW... It seems if I have this setting on so EuControl opens when the computer starts up, HUI seems to work in PT.
Strange but hey... looks like I will be launching EuControl on boot from now on instead of running it when I need it...
Cheers.
Tom
Pro Tools M-powered 7.0 stopped working - HELP tweeek Windows 5 04-13-2014 11:07 AM
Pro Tools M-Powered not working Ampig Pro Tools M-Powered (Win) 0 11-05-2010 12:22 AM
Pro-tools M powered & Profire610 not working?? AMonaco Pro Tools M-Powered (Win) 4 10-09-2010 02:42 PM
Pro Tools M-Powered 8 & Axiom 49 - Not working together...HELP Panther68 Pro Tools M-Powered (Win) 8 03-13-2010 04:32 PM
Pro Tools M-Powered Pre Release not working with Leopard bryanwilson2007 Pro Tools M-Powered (Mac) 3 05-31-2008 09:10 AM
