  #41
Old 11-10-2021, 02:30 PM
Kyle Splittgerber's Avatar
Kyle Splittgerber Kyle Splittgerber is offline
Default Re: Q regarding how to connect TC Clarity M
Originally Posted by Southsidemusic View Post
Here is the i/o
And as you see on the above pix all adat out says n/a
Thanks. Please post a picture of the Bus tab. My guess is the ADAT outputs are not properly assigned.
Kyle Splittgerber
Senior Principal Product Designer
Berkeley, CA
  #42
Old 11-10-2021, 02:40 PM
Southsidemusic's Avatar
Default Re: Can anyone do a step by step on using the optical as adat
Originally Posted by Kyle Splittgerber View Post
Did you try this step for step?
-Ensure Clarity is configured to receive S/PDIF input
-Play back in Pro Tools and see if Clarify receives the signal
Cllarity only have Drive or usb and under drive it says optical as seen in the pictures. I thought we could use the optical ports on carbon now with the new firmware to send optical and or adat.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
  #43
Old 11-10-2021, 02:45 PM
File Type: jpg 6B879CA9-ADEF-4639-AF93-0EC440D2DC52.jpg (72.6 KB, 0 views)
Best Regards
Christopher
#thestruggleisreal
WEBHOME
  #44
Old 11-10-2021, 02:47 PM
From the image you sent, the Clarity appears to be locked to Optical being fed by Carbon. So, that's great. The issue now seems to be that you don't have busses mapped in I/O Setup properly. Once you fix that, Pro Tools will route Optical S/PDIF signal via ADAT 1: 1-2 over to the Clarity. And, hopefully it's properly received so you see metering activity.
Kyle Splittgerber
Berkeley, CA
  #45
Old 11-10-2021, 02:48 PM
Next pic adat pops up a bit below too so cant get a picture with all adat as far as I know.
File Type: jpg BA87C92E-FC82-44CE-B685-5F4F2BF3CA03.jpg (81.5 KB, 0 views)
Best Regards
Christopher
#thestruggleisreal
WEBHOME
  #46
Old 11-10-2021, 02:50 PM
So how do i route this? Thats what i been trying since thursday
I am a music producer and usually we have intern wizzards but due to covid we have to do this ourselves and still dont get why no one can call and just log into our mac and set this up right after all I do a helluva lot for avid and this is greek to me
Best Regards
Christopher
#thestruggleisreal
WEBHOME
  #47
Old 11-10-2021, 02:56 PM
Here are even more adat under bus with n/a after adat text.
File Type: jpg 5415CCC1-A38C-4525-99A8-3815007B7169.jpg (73.1 KB, 0 views)
Best Regards
Christopher
#thestruggleisreal
WEBHOME
  #48
Old 11-10-2021, 03:02 PM
Every bus in that screenshot, except MON L-R, is not mapped to a hardware output. If that's the case for all the other paths (hidden in the screenshot) then this is why you aren't getting digital output from Carbon. This session has a lot of extra paths that aren't relevant to Carbon. I need to see pictures or video of the entire I/O Setup > Bus tab showing every path. So, you'll need to scroll so I can see all of the mappings. It looks like you just don't have things mapped correctly yet.
Kyle Splittgerber
Berkeley, CA
  #49
Old 11-10-2021, 03:16 PM
We only use the Dsub 8 in 8 out. Not the preamps etc. And those 8 goes to 2 x Flock audio PATCH 32/32 and we have to so we use the ins and outs when we need to make a vocal chain or any chain as we have over 70 high end outboards so is there any easier way like it is on our Apollo X 8P units? We just do a delete all paths and default them again on in/out/bus?
If not what video do you need me to film? As i said this is NOT my thing and both carbons act the same (10.000 dollars) and cant get a optical port to send as easy as the X series which are much less $.
What do i need to do exactly? 6 days and still nothing! Thanks BTW
Best Regards
Christopher
#thestruggleisreal
WEBHOME
  #50
Old 11-10-2021, 03:22 PM
First part
File Type: jpg 70A42E4D-FF08-478C-AA31-E383E53CB9F6.jpg (72.6 KB, 0 views)
Best Regards
Christopher
#thestruggleisreal
WEBHOME
TC Clarity X antonis Post - Surround - Video 0 05-02-2018 10:32 AM
TC Clarity M priorytools Avid Pro Mixing General Discussion 1 09-08-2016 02:10 PM
Is anyone using Clarity X? antonis Post - Surround - Video 0 03-08-2016 07:15 AM
Mic clarity bannerj 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-21-2004 10:07 AM
Clarity in mixes citi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 29 06-20-2002 11:54 AM
